MartyMcFly3
Alright, this is getting to the point where I'm about to take a baseball bat to all 3 computers in my house.
I have SBC YAHOO DSL (Speedstream 5100b modem). I also have a LinkSys BEFSR41 ver 2.0 router. I upgraded the firmware for the router quite a while ago and it was working fine, so I don't believe it's a firmware issue.
When NOT using the router, a speed test on dslreports.com shows that the connection is 673 down/317 up.
When I connect the router, the main computer goes to 242/147. User 2 on the network is 282/199, and User 3 on the network is 425/221...
Two of the computers use AOL (I can't ween my parents/sister off it) and the other uses AIM/Yahoo Messenger. For the past week, it appears that suddenly the port AOL uses (Port 5190 i believe), as well as the port for Yahoo Messenger, seems to be blocked for some unknown reason. AOL/AIM/Yahoo will not connect at all using the modem OR router. This occurred Wednesday of this past week and is still an issue.
The connection is just horribly slow compared to normal. For instance, when browsing anandtech while connected to the router, I will often have to hit reload multiple times for it to FULLY load.
Even worse, at times the connection completely drops out. When this happens, I end up having to go to the main computer, unplugging the connection from the modem to the router and plugging it in the main computer. Then, after I re-establish a connection with the modem, I plug it back into the router, reset the router, and it's fixed. Having to do this practically every day is beginning to become a serious hassle.
Things I've done to try and fix it:
Reset Modem
Reset Router
Ran HijackThis on the machines (Nothing out of the ordinary found)
Ran AdAware and Spybot S&D (Nothing out of the ordinary found)
Please help. Im starting to go crazy over this problem.
Reset Modem
Reset Router
