connection of IDE cables to drives...help
screw3d
I hav a HDD, a CD-RW and a DVD drive...
Right now, HDD is on primary master, CD-RW is on secondary master, and DVD on primary secondary.
Is this set-up ok? or do you people hav any better suggestions?
thanksss
All depends on what you do. If you just watch movies on the DVD drive, put it on the same channel as the hard drive. If you do alot of ripping from the DVD to the hard drive, leave things the way they are.
Basically you just want to separate the two items that you mostly use at the same time.
The set-up's fine and to add to bozo 1's statement = If you do direct burns from DVD to the CD=RW leave it alone. If it ain't broke...
HDD's work best alone on the primary channel, and can be paired with another hard drive as the slave.
If you put an Optical drive on the same channel as a HDD, it has a tendency to slow down the transfer rate
of the hard drive to match the rate of the optical drive. Most hard drives now run as either ATA100 (WD)
or some (Maxtor) run at ATA133. Since most Opticals run at 66, you could be slowing down the ability
of the Hard Drive to move data by 33% to 50% under it's design capability.
Be better to set the HDD by itself, and pair the DVD & CD-RW together on secondary channel .
The DVD should be the Master with the CD-RW as the Slave. Some say the Burner should
be on the master, but my experience is that it works better as a slave from the DVD player.
CaptnKirk your reply is for Puters built back in the Socket 7 days and no longer apply's today's chipset.
I would have to agree with LED on this argument, and espcially if he is burning from the dvd to cdrw (cd backups for example 😉 ) then it is important to have them on separate channels to prevent a buffer underrun....
Why take the chance? The risk is still there
Because of what Mrdzone stated... with the newer chipsets there is no risk of the Optical Drive slowing down the HD.
