- Mar 2, 2001
- 8
- 0
- 0
I am trying to connect a CD-ROM into my computer using the ide2 connection from the motherboard.
The jumper is set to master and i have set the bios to auto on the secondary master. When i boot the PC the screen tells me that it can see the CD-ROM but when i get into Windows i cannot see D drive.
I tried the CD-ROM as a primary slave, switching the jumpers and configuring the bios and then the CD-ROM worked ok.
I think that may be the ide2 connection on my motheboard is buggered. I tried a different ide cable that i knew worked but still no joy.
Any ideas ?
If i do use my CD-ROM on the primary slave will the performance of my system be affected ?
Thanks
