connecting zip drive to what cable?
clay
49
Hi,
If one IDE connector goes to the DVD and CD-RW/R, and one goes to the hard drive (and it is recommended not to pair up the hard drive with something slower), where do you connect an internal zip?
Thanks.
[And there are only two IDE connectors on the motherboard]
rpeAMP
56
By what you are saying, the only place that you could hook it up would be with the hard drive, unless you buy a PCI controller card such as a Promise card that will let you have more IDE ports.
Sugadaddy
Banned
May 12, 2000
6,495
It won't slow down the hard drive unless you're trying to access both at the same time (like copying a file from the HD to the zip).
I would hook them up like this:
Channel 1: Master->Hard Drive
Slave->DVD drive
Channel 2: Master->Burner
Slave->Zip drive
Don't forget to adjust the jumpers if you switch them...
