I have one motherboard fan header and two 80mm case fans I want to hookup to it..
Question is.. Is it OK to do this? The reason I want to use the fan header instead of a molex is because of the RPM sensing / automatic temperature control.
If I splice the two fans (power to power, ground to ground, rpm to rpm) into one wire of each and plug that into the board will I get correct RPM sensing and will it safely power both fans?
Thanks!
Thanks!
