- Oct 31, 2004
- 323
- 0
- 76
http://www.muzzleflash.org/cables
So I'm setting up my beautiful new box (I FORGOT TO ORDER A HD, I SWEAR IT WAS ON THE ORDER, I would bet the soul of my grandmother that it was, but it wasn't in the order or on the invoices, and the price was the same as it was when I thought I had the HD, I guess I never had it on, but didn't I copy and paste my shopping cart on here with the HD in the list? Maybe someone filched my HD and added the 88 dollars to the total of my charge..) and the cable colors aren't standard.
I will be able to continue when I know what the different colors mean. IE: if a cable is supposed to be red and black but is pink and white, which one is equivilant to the black? A lot are another color and have white.. I SUSPECT that means something. Once I know that I can connect those cables up. As to the cdrom (EIDE?) that's just a nagging question I have.
I attached the processor and the heatsink + fan (had to remove the stock mounting system to do this but it worked... heatsink is on pretty tight, hope it won't hurt the cpu), and I'm ready to do the rest except the one thing has me a little stymied.. the power and reset stuff. And some from the top flipbox (case has usb ports, firewire, and audio ports on top too). Also I'm not sure on the USB plugs.
Board = Asus A8V deluxe
click resized to see more reasonable pictures, I left the fullsize for those wanting detail.
apparently I have two little clusters of USB plugs on the mainboard, each two rows wide, I guess that's four USB ports. I have an addon USB card for two USB plugs that would take up one cluster, but for the two plugs on top of the case, it's divided into seperate plugs, I assume they can go one on either cluster or both on one cluster. I had them one on each, and also there were slightly different numbers on each one. Odd.
The firewire for the top plug was seperated into little boxes for each individual wire. I said screw it for that one as the audigy has a builtin firewire and a plug for the mobo that is one single unit.
As for mic and audio plugs on top, I have the audigy in front.
So really it's just for the USB.
As for the reset and power, you can see in the pictures.
I included some of random things that puzzled me although probably eventually I'll figure them out. The cd-rom cable included with the mobo has no protruding ridge like the HD cable (why is the hd cable given more wires if they're both the same?)
Also, since I have no HD and am going back to NY for a bit leaving the pc here making an order of a new hd from newegg within a week or two impossible, is it possible to take my existing HD on my crappy box, remove all the drivers for the motherboard and hardware, and put it in mine?
That way I can keep my registry settings for things like yahoo (meaning the IM logs which are wonky that way) and still have a (slow) HD in it.
I would back up the registry, move the files to the second part of the disk (it's a 60 partitioned to 20 (os and some programs) and 40) and format the small partition and use it except I no longer have my XP PRO disk.
- A frustratedly happy plagiarist who has never built a pc from scratch before but will do fine except for things not clearly documented where he has no experience to guess on.
