connecting santa cruz digital output to a receiver...
$pade
I want to connect the digital output of my santa cruz to the coaxial input of my receiver. Does anybody know the name of the cable I need that at one end plugs into the mini jack of my sound card and at the other end plugs into the coaxial input of my receiver?
Possum
536
Basically, the Santa Cruz FAQ on the Turtle Beach FTP site says to use a minijack to 2 RCA adapter/wire, and connect the red RCA as the digital out. If you want to just try it, any RCA cable (using a single side) will probably work ok to transfer the digital signal from the minijack-to-RCA adapter to your receiver. But audiophiles would say you should use a "proper" digital cable instead.
MrWhiteUK
625
I have the SC connected to the coaxial on my receiver. What you need:
1 * Normal RCA lead (think only requirement for digital is it is 85ohms, most are fine)
1 * 3.5mm -> 2 RCA converter
SC --[ >------------------< Receiver
converter rca cable
Take one end of the rca cable, plug both (red/white) plugs into the converter, plug the 3.5mm part of the converter into the SC
At the other end of the cable you will have 2 rca plugs, 1 is Dolby Dgital only stream and the other is the equivalent of a normal soundcard line out (ie it outputs everything) I use this one. The output from this cable is 48kHz pcm (same a CD data but at 48kHz)
Hope that helps.
