The Dancing Peacock
So I have the motherboard in the tray, I have the chip in, the heatsink installed, got the cliip down no problem. Now I'm looking at the motherboard book, and it shows me where to attach the power cables for the fron LEDs, the power and reset buttons, and the front USB ports. What it doesn't show me is which side is the positive side, and which is the negative. It just says, attach HD LED to header pins 1 and 3. I'm trying to err on the side of caution, so I don't want to plug it in any which way. Am I dumb, and not seeing something painfully obvious, that you all are gonna laugh at me for? 🙂 Or is the book not telling me everything I need to know?
About the USB ports, theres a USB1 header on the motherboard. The motherboard book calls it the extended USB module, and only points out pin 1. Will this support the front 2 usb ports, there are 9 total pins, but there are are only 4 each from the 2 front ports. Each port has 4 seperate wires :
Ground
-D
+D
+5V
Any help would be appreciated. I have an ECS K75SA and an XP1600+.
Ground
-D
+D
+5V
