Connecting neon light to a dpdt switch??
SaiyanGoku
I was wondering is it possible to connect a neon light to a dpdt switch??
I want to connect two leds to the switch, so that when its on or off a led with be showing.
Can you plz provide links.
thanks
You can use a dpdt switch.
You could use a spdt switch to do the same thing.
Connect your 12 volt positive lead to the
center terminal of the switch.
Connect your neon light and your 'on' LED
to one side of the switch, connect your 'off'
LED to the other side of the switch.
(LED)
(NEON) ON------------C-------------OFF (LED)
Just be sure to use a resister with the LEDs
Hope this helps.......
