Connecting copper drain pipe to cast iron stack
Tommy2000GT
1,832
The plumber connected the copper drain pipe to the cast iron stack. I know copper and cast iron should not be connected together without a dielectric union otherwise corrosion will result. However there is a brass fitting between the copper and cast iron pipes. I heard brass is enough to act as dielectric union. Is this true?
Greenman
22,373
6,507
You'll be dead before it becomes a problem. Let your grandchildren worry about it.
Tommy2000GT
1,832
San Francisco, PVC not allowed.
Would an iron pipe be more ideal or is my setup typical? It's for the waste stub coming out of the wall.
The plumber says he is a commercial plumber and says he tries to use good materials. He is even using L pipe as opposed to typical M pipe for the copper supply lines inside the walls.
mizzou
9,734
54
Copper waste drain? Seems like such a waste of good copper.
Also, why do you have compression wraps above and below the tee? I'm sure it works, but it just looks like a very odd combination with steel wraps, cast iron stack, and copper drain 8|
Tommy2000GT
1,832
The clamps on the tee connects to the vent pipe and waste pipe going to the main waste line.
Tommy2000GT
1,832
That's exactly what I thought myself
I agree with both of you. However when I talked to the plumber today he said he has always done it like this in commercial buildings. But I am still skeptical because I have never seen anything like this.
calahan
I hope it works without problems at least couple years
paperfist
6,539
287
www.the-teh.com
This. Have to ask the bro, plumber, but I've never heard of a copper drain.
Cut it out, sell it, pvc replacement, profit.
My friend just bought an old house here in the NE. When I went into his basement I just about passed out. Copper waste lines everywhere! I said dude scrap that stuff and it'll pay for that new A/C condenser you need.
I've never seen copper strapping like what's in the OP picture though. It has to be worth some good coin!
Tommy2000GT
1,832
The copper strapping is supporting the supply lines.
waffleironhead
7,084
586
Holy cow! Why not?! Worried about toxic fumes if a house catches on fire (which would be eclipsed by the toxic fumes from the mattresses, any vinyl, couches, pillows, tons of fabrics, clothing, etc.)
If it is anything like the Chicago area, its more to do with an active plumbers union lobby.
Tommy2000GT
1,832
I know, I just never seen thick copper strapping like that before. I used to rolled perforated strap.
I think he has good intentions to try to use quality materials like the thick copper strapping and copper drain pipe. But sometimes they might not be the most ideal like the copper drain pipe.
Tommy2000GT
1,832
Now I see a galvanized preforated strapping securing the copper drain pipe to the stud. I asked the plumber about this and he says the galvanized strapping won't stretch like copper and keeps it tight. I asked him about corrosion but he doesn't seem to think it's a big deal because there shouldn't be moisture inside the wall.
paperfist
6,539
287
www.the-teh.com
Silly question, it looks like everything is stubbed out for future connections. Seems kind of crazy to do a drain like that in copper just to cut it later.
What diameter is the copper drain anyway? Almost looks like 2"
Copper is soft, but I'd rather have copper on copper. Plus where's that pipe going on such a short run, so can't imagine there's much flex to it.
Looks like he has stainless screws going through the copper strapping too which is a corrosion problem. Also, just 1 screw holding the strap in the center?
Greenman
22,373
6,507
What the plumber has done is fine. I've removed brass to iron fittings that were 60 years old and never leaked a drop. They were corroded in place, but would have easily lasted another 30 years.
Greenman
22,373
6,507
The cast iron is "no hub", all the connections are made with bands.
