DeadSeaSquirrels
With all the hotdeals it was hard not to snag up a mismatched brand wireless router. Now I am trying to figure out how to hook up my new wireless router to my existing router. I've read a lot of articles, most of which regurgitates what I already know, and I haven't seen one that talks specifically about what I need to do, though I may be able to extrapolate some information if I knew more.
From what I've read this is what I am planning on doing. Connect the wireless router's WAN port to the the wired (main) main router's uplink port via straight through. Set the wireless router to disable DHCP, set the wireless router's WAN IP to some sub-domain of the linksys address (192.168.1.2, etc.).
But upon reflection that just doesn't seem right. How does the laptop (which has both wireless and wired capabilities) know to grab a connection from the wireless router if the DHCP on the wireless router is disabled? I've read some articles that says I should connect a straight-through from one wired port (not the uplink) to one port on the wireless (again not the WAN port), but that doesn't make sense to me.
I need to set it up so that my laptop can grab an IP from either the wireless or the wired (with preference given to the wired router), but I don't see how that is possible without having both DHCP services on. So it sounds like static IP is the way to go, but does that mean everything on my network has to be static IP? Any help or a link to an article would be greatly appreciated. Thank you.
