Originally posted by: YOyoYOhowsDAjello
I think you want something like this mono 1/8" to RCA female and then run a digital coaxial from that to your receiver.
This is the adapter I currently have, and I have Philips Digital Coaxial cable which I know is right. So the only difference would be that I need a mono 1/8" end instead of the stereo one I have?
I think so, because it's only sending one signal. Again, haven't done this before so unless you can buy it and try it and then return it, get some more opinions first 🙂
Originally posted by: DaveSimmons
For many soundcards you must go into the mixer or other soundcard software to turn on the digital out.
Note that with a digital connection only DVDs will be in 5.1, game audio will be 2 channel PCM stereo.
For 5.1 channel game audio you need to use 3 x stereo analog outs for FL, FR, Center, RL, RR, subwoofer/LFE. Then plug the 6 RCA plugs into the DVD analog in on the receiver.
