- Feb 24, 2001
- 14,513
- 4
- 81
Say I have an HTPC with DVI out (7900GT)
I have a Panasonic 53" rear projection TV (x54 series that does 1080i) that has HDMI in as well as a bunch of other inputs.
I'd guess the easiest way to connect the two would be a dvi/hdmi cable run between the two. And I guess use powerstrip and run some resolution around 1920x1080 (as it is a 16:9 set and not 16:10).
It won't be used for text, just movies, and since there isn't really a native resolution...
Will HD-DVDs (from say Microsoft's X360 player) output over HDMI fine? Or does it run into HDCP issues and should I just get a card that does component out?
