Connecting a non-powered sub (used in my car) off of a home 5.1ch receiver
BigToque
11,700
The sub output of my receiver requires the use of a powered sub. Is there anything I can do to connect my sub to the receiver? Possibly an AC -> inverter? that still doesnt solve the problem that the receiver has an RCA input and my speakers are just wire.
KEV1N
2,932
My non scientific point of view: it's not going to sound very good.
v3rrv3
1,826
Omg, i have, what do I win? :eek: BTW my sub's nearing completion Viper(excluding the veneer, won't do that for a long time :p
- Kevin
Black88GTA
3,430
You need a standalone subwoofer amp. Basically you have line level outputs from your receiver, which provide the signal (which basically tells the speakers what to do) but do not provide any power so that the speakers can do the job.
The only way I can think of for you to do this cheaply would be to hook up an old receiver or something to those line levels and plug the subs into the speaker outputs. HOWEVER, this is a VERY BAD idea, because it WILL sound like ass and you will almost certainly fvck up your subs due to lack of a crossover in the old receiver, not to mention that an old receiver probably won't put out very high wattages. You would also have to pay attention to the resistance (ohm) rating of the subs and make sure that it's within the rated spec of the old receiver.
Basically, this would be very impractical. You'd be better off buying a standalone powered HT sub that's designed for home use, rather than jerry rigging car speakers for it. The HT sub will sound a lot better, be a lot cleaner, and much safer.
Howard
47,984
11
GTA - most receivers have a subwoofer output. This means the highs are already rolled off.
Black88GTA
3,430
Ah......true :eek:
I wasn't thinking of that when I posted.
ElFenix
102,405
8,585
just a bare sub? if you build a housing for it along with a couple of speaker level inputs/outputs and a good x-over you can just attach the sub serially with the front speakers.
Pepsi90919
use an old AT power supply to supply the 12 volts you'll need to power the car amplifier for the sub and hook up your receiver outputs to that.
thomsbrain
18,148
wouldn't be able to use too powerful of an amp like that, though. most PSU's can only put out a fraction of their total power through the 12-volt rails. but i bet you could get a 200 watt amp working with a 300 watt PSU.
