Originally posted by: Jagercola
Tiger has one for $299 after rebate then Dell had one for $285 and $300 at the beginning of the week.
Originally posted by: JimmyH
Not sure how hard 520mhz is to hit on the core as most I have seen has gone higer. It uses a copper heatsink unlike the cheap aluminum on the GTO2s. R423>R480 clock for clock.
Mine does 600mhz on the core w/ the stock heatsink and NO volt mods. I used W1zzard's bios from techpowerup! to get 16pipes and atitool to overclock.
Originally posted by: munky
Looking at the pictures, the sapphire x800gto doesnt even have an external power connector, but the connect3d gto does. All the real x800xt/x850xt cards also have an external power connector, so I wouldnt count on unlocking the sapphire gto.
I'd go for it. Its pretty much 100% success unless you got a AsRock ULI mobo. It'll work but not in a AsRock ULI board.
How come no play on Asrock?
jlbenedict
400w isn't alot and X2s do suck down power. Does your 12v drop alot under load? After u unlock the 4 pipes it'll draw even more power. Never heard of core not hitting 500mhz. Maybe u got a dud core :-(
jlbenedict, 660mhz on the core. Holy Shi*! Crazy what a burn in can do. My atitool only goes only to 637mhz. Tried that and no prob w/ 2d but chicken to try that at 3d load. Looks like you got a monster on your hands, from Dud to STUD w/ a burn-in.
Its a copper heatsink. Just learned to set 100% fan in atitool. DOH. Got it 100% fan speed after 50c and its running cooler under load ~71c at 591/580 on Quake4. I'm done w/ soft mods and will go for some "el cheapo" hard mods when I get some time. Here's my end result w/ 16 pipe flash + 100% fan speed + 2 case fans.
Screenshot
