Connect two routers wireless
recis90
I am a newbie, I want to know how to connect 2 wireless router wireless.. I need to extend the range of wireless connection in my house.
Is there any specific router I need to buy. I already have linksys BEFW11S4. I am planning to purchase 2nd wireless router.. is it possible to connect to my existing wireless router ?
any documentation ?
thanks
recis90
nweaver
6,813
connect how? Wired connection between the two, or wireless bridge type setup?
simple answer would be connect a crossover cable from a switchport on each router. Then they are connected.
JackMDS
29,549
425
Very few Entry Level Wireless Cable/DSL Routers can talk one to the other (98% can Not do it).:(
Unless the data sheet lists the Router as a WDS,:thumbsup: or having the capacity to be configured as a Client, Group Bridge, or a Repeater. It will not talk to another Wireless Router.:thumbsdown:
The Buffalo 802.11g and some of the Belkin 802.11g are WDS
Link to: Wireless Network - Configuration Modes.
If you want to Extend Wireless Coverage using a second Router May be this can Help.
Link to: Extending the Distance of Entry Level Wireless Network.
Link to: Using a Wireless Cable/DSL Router as a Switch with an Access Point
Link to: Wirelessly Bridging Home / Network.
:sun:
