Originally posted by: MX2times
Just use the free trial of GoToMyPC. You and your brother will be walked through the steps. Its so simple....a caveman could do it
Originally posted by: mulletgut
If you both have Win XP, just use the facilities that Microsoft built for you. It's already there!!!
Start>Help and Support>Invite a friend to connect to your computer with Remote Assistance
Just get him to follow the prompts. It is easier if you both have msn actually but the email method works fine too. I prefer this method to using remote desktop because the user can see what's going on as you help. You have the option of taking control of the mouse, there is a chat window, (I prefer to be on the phone) and because they can see what you are doing, they may be able to learn a bit.
You will both need to be on broadband otherwise it's is painfully laggy.
I don't see the need to install aditional software for stuff like this.
Originally posted by: StevenYoo
I second RealVNC
*EDIT*
mulletgut, I didn't know about a walkthrough thingy in the help section! That's super useful. Will it also help you to forward the other person's ports?
I second RealVNC
*EDIT*
It wont assist with ports unfortunately.
Most remote desktop software will let the remote user watch though, so thats not a big deal really.
I second RealVNC
*EDIT*
you won't need to do any port forwarding....if you both have an MSN email account , and MSN Messenger , both of you log in , and have him go to the options menu in Messenger , and have him send you a remote assistance request. You will get a prompt like the video / audio prompts when you are Im'ing. and it will then bring up a copy of his desktop on your monitor. Then you click on "take control" and he has to click the accept button...and then you are in control to do your thing. He will have to restart the machine of course. I use dual monitors , and that makes it really easy to put the remote assistance up on one monitor , and use my other monitor for information gathering purposes..... or whatever else you are doing...
Configuring Port 3389 to Enable Remote Assistance
Remote Assistance runs over the top of Terminal Services technology, which means it needs to use the same port already used by Terminal Services: port 3389.
