Connect 3D X1900GT or XFX 8800 GTS
nasttcar
335
Building a new system with E6400, P5B Deluxe WiFi MB, 2GB Corsair 1024, 500GB Sata HD, 22" Viewsonic, and cannot decide on a video card.
As you can see this is a pretty high end system and you would think I would be trying to decide between GTS or GTX, but I just don't play alot of games. Now this system may make me alot more interested in doing so.
I do alot of AutoCad and Rendering work.
Help me with logic and thought process to decide on this.
I have all the parts on order and need to get moving on this.
thilanliyan
12,072
2,280
IF you don't play a lot of games AND you need to save some money...X1900. If you don't need to save much money then 8800GTS. The 8800 would last you a bit longer probably, and is a DX10 card...which doesn't mean much right now...but probably will a bit later on.
AlgaeEater
960
There really isn't a need to convince yourself you need the higher card when you don't game much or if at all.
Think of all the food, clothing, toys, gadgets, bills you can buy/pay off with that saved money.
About 2 years ago I was in the same boat as you when I was upgrading my computer, and decided to go "Mid-range" rather than "high-end" and saved myself $700 in the process. I used that money to redecorate my room, buy a fishtank, get a personal fridge, get some nice wall art, upgrade my cell phone, buy some new prescription glasses and finally get a new pillow for my bed. I don't regret that decision one bit.
Just take a step back a moment and prioritize your upgrade, and then everything will be clear.
n7
21,281
4
No point in a high end card if you not gaming.
As for rendering, a card designed for that would likely be better...
I'd recommend getting both, & then sending the 8800 GTS to me as a charitable tax deductible gift :thumbsup:
nasttcar
335
Thanks for the all the thoughts and advice.
Regarding the charitable deduction comment. I would love to do that for you but I have a kid in college and right now he is getting all my charity and more, if you know what I mean.
Actually, after I get this rig going I think he is going to pitch a fit when he sees how well it renders his 3D stuff.
Captante
30,354
10,880
You could also consider somthing in between the two ... I'd suggest considering an X1950 Pro which will out-perform the GT in 3D apps & the occasional game, or you could also consider a 7900GS ... both will run about $160.
The only other thing to think about is that while ATI drivers are for the most part very good these days (in many cases better then Nvidia), Open-GL is still one place where Nvidia is considerably better, so if you do any 3D rendering using it, you would be better off with them.
MSI X1950 Pro @ $156 + $7 shipping
EVGA 7900GS @ $160 + $6 shipping ($15 MIR)
