Here's what I've got:
P4 2.4c
Abit IS7
512 PC 2700 ram (1 stick of generic, one stick of Mushkin)
I only use one of the sticks at a time for testing.
I'm noticing that when I run the processor at default 2.4 and set the generic memory to run at 166 with totally relaxed timings, it all runs fine. When I start O/Cing the processor, but keep the memory at 166, the system fails Prime95.
When I put in the mushkin memory, prime 95 passes. I don't get it. I'm not pushing the generic memory any harder, yet it's failing when the processor is O/Ced. Any ideas as to why that happens when I'm not pushing the memory any harder?
Second question is that even with the Mushkin 2700 memory, I can only get to around 2.8 GHz stable. When I go up to 3 GHz with the same settings for memory (totally relaxed), I again start getting prime 95 errors after the O/C. Based on my previous experiment where the memory was causing errors even though it was running at the same speed & settings, I'm wondering if buying some PC 3500 memory is going to allow me to o/c better or if it's more likely that I've hit the ceiling for my processor.
P4 2.4c
Abit IS7
