Confused between setting up Vista Home 64 bit or 32 bit edition.
Apocalypse23
1,467
okay, so I've finally decided on getting the following setup, not sure if I need to get Vista home premium 64bit or 32bit. Mind you I will be gaming the latest games i.e UT3, Quake Wars ET, Crysis, WOW, HalfLIfe expansions, COD 4, all the latest crap....since i also have 4 gigs of ram, should i just close my eyes and opt for 64bit vista? The awful dealer I went to already kept bragging about how all his customers bought 64bit home and returned them since they were'nt compatible with a lot of software, at that point i got annoyed and decided to hold on purchasing any windows. Help would be appreciated.
MY setup:
Patriot Extreme Performance 4GB 2X2GB PC2-6400 DDR2-800 CL4-4-4-12 EPP Dual Channel Memory Kit - $149 - $119 after rebate
EVGA E-GEFORCE 8800GTS Crysis Edition 670MHZ 512MB 1.94GHZ DDR3 PCI-E DVI-I HDTV Out Video *IR-$20* -$339 - $319 after rebate
Scythe Infinity 5 Heatpipe CPU Cooler LGA775 S478 AM2 S754 S939 S940 120MM 1200RPM 23.5DBA 46.5CFM - $49.99 OR OCZ Vandetta heatsink with fan 39.99
E8400 core 2 duo - $219
ASUS P5K-E/WIFI-AP ATX LGA775 P35 DDR2 1333FSB 2PCI-E16 3PCI 2PCI-E1 SATA2 Sound WLAN Motherboard $167.90
Coolermaster Elite RC-330 ATX Blk Case 4X5.25 2X3.5 5X3.5INT No PS 1X120MM Rear Fan Front I/O Panel
Coolermaster Extreme Power 650W ATX 12V V2.01 Silent Power Supply 20/24PIN 120MM Fan
Apocalypse23
1,467
Originally posted by: apoppin
if you are asking about performance differences, we are evidently the first forum on the Internet to be exploring this - performance differences due to 32- vs. 64-bit OSes in 4GB gaming rigs .. results beginning hopefully in a few days
Vista32- vs. Vista64-bit OS Showdown
Cool, I've subscribed to your thread. Thanks and good luck!
HeXploiT
4,359
There's no question that you need to go for 64bit. Microsoft will be dropping support for 32bit like a rock.
Duddy
4,676
10
64bit is the future. Your rig is ALOT like my latest one. I'm running Vista 64bit and Crysis is running like it would on a console. Buttery smooth.
Mostly I have been playing CoD4, which plays PERFECTLY at the highest resolution.
lxskllr
59,367
9,895
I'd go with Vista64. I used Vista32 from Jan-Sep last year, and Vista64 from Sep-present, and I noticed no difference either way. With Vista64 you'll get to use all of your ram, and you'll be more future proof.
apoppin
34,890
alienbabeltech.com
from what i am currently experiencing, installing both versions on identical HDs - IF your HW is new and 64-bit - there is no reason to not go 64-bit
despite my double negative, Vista 64 is a good way to go
as to the 'benchmarking' .... expect some results ....
soon ;)
'when it's done'
:p
BladeVenom
13,365
16
Last I heard Windows 7 was going to have both a 32 and 64 version.
gpse
477
MY setup:
your setup is alot like mine, go with Vista 64-bit.
-Shaun
Asus P5K-E wifi
e6600 @ 3Ghz
4GB Patriot DDR2 667
EVGA 8800 GTS 512
500Gb Seagate 7200.11
X-Fi XtremGamer
450Watt Ultra PSU
Vista Home Premium 64-bit
Piuc2020
1,716
I hear support is pretty good now (heck even Omega Drivers are supported now) but I'm not sure about performance, personally I'd play it safe and dual boot Vista 64-bit and XP Pro 32-bit.
3NF
1,345
I was dual booting Vista 32 and 64bit for awhile there, and I can't tell any major difference in performance. I can only recall one program compatibility issue (CoreTemp), but a simple Google search solved that problem. Nice thing about 64bit is that can make use of all 4GBs for RAM.
If your hardware supports it, go for it.
Piuc2020
1,716
Yeah I'm with that notion too but you never know when you might need Windows XP 32-bit, it doesn't hurt, it's only 4GB more on your HDD.
3NF
1,345
True, I just found out that Active-TV for the D-Link DSM 520 will not install on Vista 64bit! :) Therefore, I'm using a virtual machine running XP 32bit to run Active-TV when needed.
