Confused and need help - DDR2 and DDR3
edm
527
I currently have a ASUS M4N82 Deluxe AM3/AM2+/AM2 NVIDIA nForce 980a SLI AMD Motherboard Here
And a AMD Phenom II X4 940 Black Edition Deneb Quad-Core 3.0 GHz Socket AM2+ 125W Here
I am trying to get from 4 gigs of ram to 16 gigs with the least amount of work, and cost.
My first question is, can I simply swap out the current DDR2 ram I'm using for DDR3 ram (240 pin)? (DDR3 is of coarse much easier to find and a lot cheaper).
My second question is, if I purchase a new motherboard that supports DDR3, will that Phenom II work with DDR3 memory?
Or are my only options to 1) purchase a new motherboard, CPU and RAM. 2) Find some old DDR2 ram.
Thanks
MongGrel
38,466
3,067
121
NM, I really know nothing about the rig your using.
Buying new and using DDR4 is another option other than only, but not what your doing it looks.
fralexandr
2,281
222
www.flickr.com
buy 4gb sticks of ddr2 on ebay... AMD Only, high density RAM 16GB 4x4 kit DDR2 800 ~$27
http://www.ebay.com/itm/Samsung-16G...Motherboard-/161498704303?hash=item259a12a9af
there appear to be a lot of 16gb AMD Only high density DDR2 RAM kits "New" for really cheap?
page 34 of your user manual should say that the M4N82 motherboard supports SAMSUNG M378T5263AZ3-CF7 4GB sticks
http://www.manualslib.com/manual/432332/Asus-M4n82-Deluxe-Motherboard-Atx.html?page=34#manual
Also, it might be prudent to check if you have a 64-bit Operating System, as 32-bit Operating Systems do not benefit from having more than 4GB of ram
1) DDR3 will not fit in a DDR2 slot. The pin layout is different.
wikipedia
2) AM2+ processors don't support ddr3 RAM. If you want to move to DDR3, you would need to purchase a different processor and motherboard.
Seba
1,599
259
Your motherboard supports DDR2 only. You can not use DDR3 on that.
Deders
2,401
To clarify, your processor will support DDR3 but your motherboard will not. You will need an AM3 mobo if you want to go down that route.
fralexandr
2,281
222
www.flickr.com
edm
527
Thanks for the help all.
Yeah. I was finding conflicting information online about whether this CPU supported am3 or not. Since I'd have to upgrade the motherboard anyway, I will probably hold off on upgrading the mobo/cpu for now. I will try to find some cheap ddr2 on ebay.
fralexandr. I did see those 16 gig kits on ebay. Unfortunately it looks like they all ship from China, which I'm a little iffy about ordering from. However, there are some 8gig samsung kits shipping from the US, so that might be an option to hold me over until I do a complete upgrade.
current setup
- Antec Nine Hundred case
- Asus M4N82 Deluxe
- Phenom II X4 940 3.0GHz
- OCZ Platinum 4GB (2 x 2GB) DDR2 1066
- EVGA GeForce GTX 260 Core 216 896MB Will upgrade to GTX 960 Overclocked 2 GB
- 500 GIG 7200rpm in raid 0
- Will add Samsung 850 EVO 250GB
- Dell S2409W 24" 1920x1080
- Window 7 pro 64-bit (will be going to win 10)
For now I think I'll just upgrade the video card (GTX 960 Overclocked 2 GB) and SSD. I can do those for under $300. Having to upgrade the mobo, CPU, and RAM would cost another extra $400-$500.
Thanks again.
Seba
1,599
259
If you change the motherboard, don't hold on that old CPU. Delay the motherboard change until you can also replace the CPU.
