- Mar 3, 2009
- 74
- 0
- 0
Upgrading my system with the components listed in my sig, and everything started well. Booted to BIOS successfully on first attempt, set SATA to ACHI, set the SSD as the boot drive, reinstalled Win 7 Pro 64 on the SSD with the other drives disconnected. Shut down, connected the other drives, rebooted, and things came grinding to a halt.
I can boot to BIOS but Win 7 won't load, all I get is a black screen with a flashing cursor. Also the DVD drive now doesn't work. BIOS recognizes it, but it doesn't respond to the eject button. I'm not sure if it simply crapped out (it was brand new as the new board doesn't have IDE) or if it's related to everything else. Flashed the BIOS to the latest version but it hasn't helped.
Any ideas what I should do next, other than replace the DVD drive? Thanks in advance for any assistance.
