If using Windows XP laptops connected to a Windows 2003 LAN server, can having both the wireless LAN connection and the hard wire/ethernet connection active at the same time cause any possible conflicts/problems in running LAN based applications, installing or uninstalling LAN based applications or any other communications between the LAN and the laptop workstation or internet communications with the laptop ?
Let me know if you may need any further details.
I may have a followup question, depending upon your the answer to the above ?
Thanks for you help.
