Configuring remote on Audigy2 ZS Platinum for WinAMP
ChiBOY83
517
So, anyone have any idea how to get the remote to bring up winamp and control the songs. I can't get it to work for aynthing; furthermore, the instructions are pure sh!t for setting up third party software w/ the remote... and i SURE KNOW i don't wnt to use creatives software for listening to music. Any help would be GREATLY appreciated
ChiBOY83
517
bump....trying to be patient.. see what happens when you play by the rules and post a quesiton in the right forum....i KNOW i woudla had this answered 2 weeks ago if it were in general hardware..hahaha
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Does creative have a forum? I think they might. I've never looked for it, but it might help you if it exists :p
AmberClad
4,914
This is not guaranteed to work, but it's worth a shot:
Open up WinAmp.
Right-click on the player.
Go to Options -> Preferences -> General Preferences - Global Hotkeys.
Check the box for Enable.
Yes, I know the hotkeys appear to be intended for ctrl+alt hotkey combinations, but this is what I had to do to get WinAmp to recognize signals from my MS keyboard's media keys (the ones that look like the rewind, fast forward, play, stop, etc keys on a typical remote). The media keys on my keyboard work on the Creative MediaSource audio player too, so it's possible that these things are somewhat standardized and it'll work in reverse too (i.e. a Creative remote will work w/WinAmp). If you find that certain functions don't appear to work, then check to see what keyboard hotkeys the MediaSource player uses, then set the same mappings in WinAmp.
gryfon
120
try intelliremote (freeware) from : http://melloware.com/download/
you must also install microsoft intellitype driver / software for the program to work, don't worry, you don't need to have the keyboard (i don't have url try google/microsoft.com search). What it does is basically remap all your creative ir remote button to keyboard key... , so next / previous button on remote can be remapped into keyboard next/previous button (the mapping is customizable). All remote key is mappable. The only complaint, is audigy function now obviously can't be accessed through the remote (such as cmss,rec). But i find it acceptable, than to find the fact the remote is useless using creative apps...
also don't forget to turn off creative remote detection (accessible from "Remote Control & OSD Settings" menu on start menu -> creative -> mediasource)
cheers.
ChiBOY83
517
THANKS AGAIN THO..i don't have to use that damn POS creative software for using the remote
...it works GREAT
WeiWei
183
does the intelliremote thing only work with microsoft keyboards ?
I downloaded the mircrosoft intellitype driver but could not install, it keep saying some error at the end of the installation.
any help ?
WeiWei
183
right after i made the previous, post, i found a very useful program that is a plugin for winamp
its called RM-X
http://www.darkain.com/rmx/download.php
for those looking to control winamp with the creative remote, i think this is a good choice. it doesn't need that intellitype program
WeiWei
183
anybody here have a logitech keyboard and have gotten the intelliremote program to work ?
when I install the intellitype software from microsoft that is needed by intelliremote, it wants to uninstall my iTouch software.
any help ?
