Phoenix86
- May 21, 2003
- 14,644
- 10
- 81
Long handle screw driver and glue on the tip. Attach to VGA knob. Wait for glue to set. Turn. Break glue off screwdriver.
Maybe?
These things can be a bitch to turn especially if they are tightened. I can't imagine you're going to get enough torque trying to be grabby with the outside, AND still have room to turn. You'd also only get a 1/4 turn before resetting with anything pliers-like.
edit: oh tighten... Hmm, you only need a couple turns so it doesn't fall out. I'd try the wire nut suggestion.
Maybe?
