Concrete wire management for coax
rsutoratosu
2,716
4
So all my wire clips flew off during the last high wind storm... the nails on these were so short.. you can literally pull them off. Anyone have some good site to get wire management for outdoor wires ? I like to use the blue concrete screws.. they seem to hold better.
jmagg
2,178
444
Drill pilot holes in the concrete to a 3/4 inch penetration with hardened nails, and reuse the old clips. A piece of wire in a too big drilled hole fixes that situation.
Jun 18, 2000
11,192
765
killster1
Banned
Mar 15, 2007
6,205
475
there are not hundreds of different kinds of clips and materials the clips are made from? hmmmmm
