Concerns with Kazaa Lite; Direct Connect and DC++
QueHuong
2,098
I AM SO FVCKING PISSED!!! I installed a few programs/updates at once and now my system is unstable as hell and I'm not sure which is the culprit.
Firstly, Word XP freezes ALL THE TIME - I insert a comment, FREEZE; I close a pane, FREEZE; I customize the buttons, FREEZE; I type a damn word, guess what? FREEZE. I then would have to press the reboot button.
I don't know if it's because I installed some crappy updates, or because I installed KazaaLite 2.0.2.
Now onto Kazaa Lite problems. I d/led the program from www.k-lite.tk then after using it for 5 mins, my whole system freezes, then I have to reboot. Then I connect K.L. again and my firewall warned me that the checksum for Kazaa Lite just changed and if I want to accept the change, I said yes. Then I was worried, so I uninstalled it a few days later. Then I downloaded Kazaa Lite again - and this time, it was different from my first Kazaa Lite exe file, in terms of file size. Anybody know what's going on here?
Now onto DC. So far, I've been using the official DC from www.neo-modus.com. Should I use DC++? What are the benefits and drawbacks of DC++ from the regular DC?
Toxic
223
No idea, but if you haven't done a virus scan, you might. (Meaning, do one from a source that is NOT on the HDD).
Reel
4,484
I used the DC and DC++ and I liked the features of the ++ better. You'll find that some of the hubs only let certain versions of ++, only allow ++, or won't allow ++. Regardless of that, I say get the ++.
