- Feb 18, 2006
- 522
- 0
- 0
I've been running an XFX 9800gt for awhile now and it's been running great for me. I had changed the stock cooler to a Zerotherm GX810 as my temps were at 80-100C and the GX810 was $5 after rebate on the egg. My temps have been 46-60C after installation so I'd say that's a pretty good result. However being a computer hardware nut I'm getting sort of bored with it, not to mention I has never very enthused by the mounting system on the GX810.
I've been looking into the accelero s1 rev2 and got interested in it. The prospect of a silent passive cooler is intriguing or even something that can get my down to 35-48C with a quiet 120mm fan. The only thing I'm wondering is about the mounting, as I have heard that it can bend the card like in the picture below. I guess if one is careful you can avoid this, I just want to know if this is something I should be concerned about. I was also looking at the 100MM scythe Kaze fan as it is only 12mm wide and would take up less space.
I've seen the numbers the cooler gets and some reviews show it getting down the 35C and some are in the 40's so in your opinion would it be any better temperature wise than the cooler i have now? I am interested in getting a decent overclock out of this card. My room temp is generally a toasty 23-25C but I imagine it will be more like 21C as spring is around the corner.
thanks
-Ray
http://img.photobucket.com/alb...ingle2003/CIMG0571.jpg
thanks
-Ray
