Concerned with static on carpet
sphfaros
There seems to be an excessive amount of static on my new carpet and I'm bringing my computer there shortly. Anything I can purchase or make on my own to prevent my tower from getting shocked?
Jiggz
4,329
In addition, you can place rubber mat or place the case on plastic wheels. But the grounding is your best and safest way to avoid static electricity.
CrispyFried
1,122
proper grounding it the best.
there are also anti static sprays you can spray on your carpet but as ive never used them I cant comment on how well they work.
Navid
5,053
You have nothing to worry about as long as the case is closed.
You should never work inside your PC on that carpet even if the PC is grounded. Otherwise, you are taking chances! Either way, when working on your PC inside the case, make sure you frequently touch the metallic part of your case to safely bring your body and the PC to the same potential.
