Chaosblade02
Motherboard: ASRock Z68 extreme 4
CPU: I5 2500k
After market CPU cooler: Cooler master hyper 212 plus
Case: Lian Li PC-A70F Full tower
PSU: Seasonic/SS-850HT Silver
I think that is everything that would be relevant to thermal issues, if any other info is required I can post it.
I plan on running the 2 6970s stock in crossfire, no overclock because why would you even need to overclock them at this time?
This concern started when I looked into my instruction manual that came with my new board, and it gave pictures of Crossfire ATI cards, and it looks like they have only about an inch to spare between them. Now my Board has 3 PCIe X16 connections, 2 are spaced rather close and the other is spaced a little bit farther away. But the instructions given said to use the two slots that were closest together for Crossfire, and the one above was only used for tri-crossfire.
Would I still be able to use the other PCIe X16 port for better spacing and airflow? I am certain I would need a longer crossfire cable, and is there somewhere I can get one?
Just to give a picture of what I am talking about here is a link to a picture of the board.
http://www.asrock.com/mb/overview.asp?Model=Z68%20Extreme4
I am wondering if I could use the PCIe X16 port to the far left and the one to the far right instead of the left and middle ones like the manual suggests?
I am not that concerned about noise, but I would be very concerned if one or both of my GPUs was pulling 80+ degrees celsius on load. I am not concerned about noise of the fans running as long as it isn't extremely overbearing.
This is my first PC I am building from scratch and I want to make sure I get absolutely EVERYTHING right. And this is one of the few concerns I have left.
My build is really close to one of Tom's hardware $2000 builds, minus one SSD, full tower instead of mid tower, I5 2500k instead of an I7 2600k. Other than that it is basically the same. Still around $2000 total after I get the 6970s.
And if I probably need to buy an after market coolers to keep my temps below 80 celsius, anyone got any suggestions of some that work well for a reasonable price? Also they won't do me any good if I can't figure out how to install them so they need to be made to where someone of average tech skill can install with no problems.
CPU: I5 2500k
