Concept: diagonal keyboard for netbook chassis
NewCityVegas
One of the reasons some folks avoid netbooks is the smallish keyboard. I wonder why no manufacturer ever made a diagonal framed keyboard, moving some of the non-core keys to the top or bottom of the core keys. A diagonal case orientation allows more space for keys although the screen hinge would have to be replaced with some other mounting method.
With a 9"x9" square chassis shape, the screen resolution could also increase to a more typical 1024x768 size instead of the non-standard 1024x600. By increasing length (but decreasing width) a square shaped notebook would also provide extra space for flatter batteries, decreasing overall height.
Assuming that a normal netbook keyboard requires 20% greater chassis width than a diagonal frame netbook:
The new ASUS EEE 1002HA netbook:
-- 10.4 x 7.1 inches - surface area 73.8 square inches
A diagonal keyboard netbook with the same relative key size:
-- 8.7 x 8.7 inches - surface area 75.7 square inches (less with rounded off edges)
While surface area is similar, the deeper diagonal unit could easily accomodate a 1024x768 screen whereas the 1002HA is limited to non-standard 1024x600 resolution.
IMAGE: http://farm4.static.flickr.com...2786450_2ff2354af3.jpg
IMAGE: http://www.trustedreviews.com/...27-eeepc1002haspan.jpg
This is obviously just a concept. I'm sure there are practical fold down or slide out alternatives to the double hinge design of a standard notebook. I can even imagine a non-detachable sliding hinge on a rail (along the rear right edge) concept. Since I prefer using a USB mouse to a touchpad, the side cutaway design actually provides more practical space for mouse movement for me and more convenient access to ports, SD memory slots, etc.
Since the 90 degree rotated square design provides ample room for 1024x768 screen dimensions, the pointed edges of a square design could be easily rounded (preferred) or chopped off as shown below.
IMAGE: http://farm4.static.flickr.com...27210_64f3da3f29_o.gif
BTW, although not shown, the screen, when not in use, would slide or fold down over the keyboard part of the chassis. When in use, the screen would either slide up (possibly along a rail of some sort) on a vertical mount or be semi-detached but tethered to sit on a swivel mount located at the rear part of the chassis.
For those who need a palm rest, a simple but sturdy clip-on or fold-up-from-chassis-bottom could be added.
Denithor
6,298
23
I personally would *never* buy one of those. My neck couldn't take the strain of constantly looking sideways at the netbook to see the screen while I hold the keyboard straight for typing.
NewCityVegas
That was my first thought too. However, after looking at the Fujitsu image again I would guess that their idea was that the user sits straight in front of the screen. Since most people are right handed and the chassis is small, you would extend your right hand just a bit farther right to type.
Denithor
6,298
23
...then carpal tunnel syndrom sets in. Bent wrists & all that.
:D :laugh:
Interesting concept but I kinda doubt it will take off.
DaveSimmons
40,730
670
IBM had the "butterfly" keyboard that opened up wider than the case, but that would require doubling the thickness of the netbook.
Butterfly
RebateMonger
11,586
Another possiblity would be to remove letters, numbers, and symbols that aren't used that often.
For instance, if we remove the two diagonal columns "7, U, J, M" and "9, O, :, ?", we get rid of 20% of the keyboard width and lose characters that are probably used in less than 10% of all words. I think that's a fair tradeoff.
We can create a singe "Wildcard Key" that can replace all of these missing characters. Incoming spell checkers will detect the "Wildcard Key" and replace it with the best guess of what the missing character should actually be.
---- Special Notice: I hereby donate my idea to the Public Domain with the hope of benefitting all Mankind. I only ask that this special keyboard be known as the "RebateMonger Keyboard". Thank you. -----
Zap
22,377
7
Remove keys that get abused, such as CAPS LOCK and !!!111!!!. also, remove shift, since fewer people use proper capitalization these days and remove punctuation because it just gets in the way when typing for online use and of cours u should just remove the letter because ou dont have to tpe ou but just the letter u instead of the word ou so u seem like u are tping in im proggis which dont nd xtra lttrs it shall b th rbatmongr kboard zap vrsion
