computers shipped with IE9, help! OOPS, problem solved.
skyking
22,775
5,935
4 new desktops from Dell with IE9 + THE online application that does not play with 9 = much sadness.
Microsoft has downgrade capability, but IE8 was never on there to begin with.
I have a support ticket in with the software company and am calling Dell now, but I'd see if there was any way to get IE8 as a download for win7 x64.
I can get it for many other OS's, just not 7.
nitrous9200
282
check to see if it was installed as an update (which it might have been) -
Control Panel>Programs and Features>View installed updates
Look under the Microsoft Windows section, and if you see Windows Internet Explorer 9, right click and choose uninstall.
You wouldn't be able to download IE8 for Windows 7 because it was built in to the OS so there never would be a need to download it normally (just as IE7 came with Vista, I haven't checked but I'm assuming there's no downloadable copy).
GoStumpy
1,211
11
In XP there is the "Add or Remove Windows Components" in the "add or remove programs" section of Control Panel... Is there something similar in Windows 7? That is where you can install/uninstall Internet Explorer usually... :confused:
skyking
22,775
5,935
did not ever have 8 to downgrade to. IE 9 is not in "add/remove", it is only in "turn off windows components". I may be screwed here.
EDIT:
I just opened these and some toshiba lappys up here today, and the lappys were good to go with 8 and I stopped the "upgrade" to 9.
These dells were at 9 out of the box.
skyking
22,775
5,935
It was, than you so much. I was stuck in the mindset that it was not an update I did. :oops:
It was done on 11/30/2011 just before shipping.
I'd be more embarrassed but I'm too happy!
