Right, so I have a PC that is barely half a year old. I've had few issues with it - every once in a while it would just freeze, but nothing that a reboot couldn't handle. But since two weeks ago, it has just refused to turn on. (Edit) It's not a no post - nothing happens when I push the power button, or the restart button. The "PWR_LED" lights up for some time when the PSU is turned on (sometimes only a few seconds, sometimes several minutes), then it fades away. But sometimes it comes back again. Pushing the power button while the power LED is still lit changes nothing.
The peculiar thing is that the PC shut down right as I was inserting my headphones (Apple Earpods) into the minijack. I'm using an integrated sound card. Is it reasonable to assume that the motherboard (or some other part of the PC) was damaged because of the minijack insertion? The headphones in question spend a lot of their time lying in my pocket. Could it have been a static discharge or something? It seemed to happen literally as I finished plugging in the cord.
Is it safe to assume that the motherboard is the issue because of the aforementioned observation with the power LED? Is it supposed to always be lit when the PSU is on? If not, could it be the PSU, or maybe the case? I do have a PSU from my old PC, but I'm not sure I can connect the new MB to it. I could try another case, but I'd rather not switch that out.
Does anyone have any help or recommendations? I would be really grateful if I could have the faulty part(s) identified once and for all.
The parts of my PC are, for reference:
Motherboard: ASUS Z170-A
RAM: 2x8 GB Corsair Vengeance LPX (DDR4) 3200 MHz CL16, WHITE
CPU: Core i5 6600K
CPU cooler: Silverstone Argon AR01
PSU: Corsair RM650i
Case: Fractal Define R5, white windowed
Storage: Samsung 850 EVO 500GB
CPU: Core i5 6600K
PSU: Corsair RM650i
