The Anandtech community has always been very helpful in the past, I'm hoping I can once again use your expert advice to help out my situation. My current build is below:
Current Build:
Intel Core i7-2600K Sandy Bridge 3.4GHz
ASUS P8Z68-V PRO LGA 1155 Intel Z68
8GB Patriot Gamer 2 Series 240-Pin DDR3 SDRAM DDR3 1600
EVGA GTX 580 SC 015-P3-1582-AR
128GB Crucial M4 CT128M4SSD2 2.5" SATA III MLC Internal Solid State Drive (SSD)
Corsair 1000watt PSU
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm
COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Steel ATX Full Tower
22" Samsung LCD Monitor
I just purchased a Corsair HX1050 PSU last night and I installed it. After it was all plugged in, I plugged the power cable into the PSU and flipped the switch. The lights on the motherboard lit up (so far so good). I then went to press the power button on the computer to boot it up. When I pressed the power button there was a time "Click" noise that came from the back of the computer, I'm guessing near the PSU (I'm not referring to the click the button itself makes when you press it down), but then nothing turned on. The fans didn't spin, no sounds, nothing. The only thing giving me hope that the PSU was supplying power was the fact that the motherboard lights were on from when the PSU itself was switched on. Any ideas as to what's going on? I'm hoping its a simple issue of plugging something in incorrectly and not a faulty PSU.
Note: All hardware prior to installation was working fine, this was an upgrade, not a replacement for a bad prior PSU.
Thanks in advance!
Current Build:
Thanks in advance!
