- Nov 24, 2004
- 5
- 0
- 0
Hello, I have a long story here but it is all part of my problem and I would be very gratefull if you could help me, the last paragraph is a sumary of my problem.
When I got home today I found out that the power in my area had been off and back on a few times today but I thought it wouldn't be a problem because my computer was off and I have a UPS with power surge protection. Anyway I try to start my computer and it won't start, it has lights on the front but nothing happens. I checked the UPS and it had no lights on so I turned it off and back on again but it beeped (meaning it was overloaded) so I unpluged everything and turned it on again but it still beeped so I think something must have happend to it and I find a powerboard and plug my computer back in. Now when I turn my computer on it says Windows XP failed to boot properly last time and asks me how to boot this time (Safe Mode, Normal, etc.) so I choose Normal and it shows the "Windows XP" screen with the loading bar. When this screen is finished the monitor goes black like it normally does just before it gets into Windows but this time it stays black for a few seconds and then the computer restarts. I have tried choosing Safe Mode and Last Good Config but the same thing happens.
I have checked all of the BIOS settings and they are fine. I turned off the "Auto reboot on system failure" setting and found that last thing that happens is a blue screen with a c0000218 message that apparently means the registry is broken or cannot be loaded. I also tried to repair my Windows XP installation (boot from the XP CD and choose repair) and it copied files over etc. but then it said something about cannot setup Windows XP, cannot setup XP on drive C:\, C:\ cannot be found on specified device, possible disk error or something. So does this mean the HDD is broken? It is not very old (about 3 months) and some of it can still be read from the "Recovery Console" and the fact that it starts to load XP. It is SATA and I don't have another computer to connect it too (they are all only IDE) to try to read from it. How did this happen and what can I do?
My other computers don't support SATA but the broken computer supports ATA so I managed to get one of the HDDs from another computer and put it into the broken computer thinking that I could boot from the working HDD and at least get Windows running (minus drivers and stuff) enough to copy all my files from the SATA drive. But it also gets to the same place at startup and then flashes a blue screen with writing for half a second and reboots. I can't see what the screen says, it all happens too fast.
Finally I tried the recovery console but it wouldn't let me create directories or copy files, even in the \Windows\ directories.
So my problem is that I cannot load Windows XP, it finishes the Splash/Loading Screen bit and then restarts, I am also having trouble repairing the Windows Installation.
I really need to get the data from this HDD and if possible get it running again like it was so any help would be very much appreciated.
Thank you,
Aston
Thank you,
Aston
