- Jan 22, 2006
- 1,294
- 0
- 0
As the tilte states, my computer won't power down. System specs:
AMD X2 4400+ @ 9x285MHz
2x512 Ballistix Tracers DDR500 @ 233MHz 2.5, 3, 3, 8
DFI NF4 DAGF
2x120Gb Maxtor DiamondMax Plus 9 SATA120Gb in RAID0
ATI Radeon x800XL
Windows XP Pro (up-to-date via Windows auto-update)
Lite-On DVDROM IDE
Samsung CDRW IDE
Antec NeoPower HE 500w.
I had one of the Maxtors running for several months as a solo drive. About 1/20 times, it would do this when selecting 'Shut Down' from Windows, but then all I had to do was hit the power button and all would turn off. Now, it won't power down at all, even when selectiing to 'Restart'. 'Restart' never would hang before. Now, I have to hold the power button down for several seconds before the unit will shut off. When I do this, upon next startup, Windows shows no sighn of improper shut down. No "Windows was not properly shut down" messages or the like.
To be more specific, it's hanging at the "Windows is shutting down" screen, not just keeping fans and lights on.
I am having no other problems at all whatsoever.
I have checked the event viewer, (before and now), but no errors are being reported.
I have checked the BIOS version, and the only update for BIOS addresses an issue I am not having.
I have toggled the S1/S3 ACPI setting in BIOS with no change.
I have tried Safe Mode with no change. It will not even power down from Safe Mode.
I have reset CMOS and loaded BIOS defaults, (Overclock off), with no change. It still won't power down.
Temps are completely normal.
PSU is all good.
Neither drive is failing, checked with Maxtor's PowerMax tool.
I have had everything in this computer changed since the first time the solo drive did this except the motherboard.
Please, PLEASE, help me figure this out!
EDIT: Oh, I have a Seagate 120Gb SATA that I use as my backup HDD and when using it, (the data is identical, the source of the data on the array from cloning), the system operates completely fine.
DFI NF4 DAGF
ATI Radeon x800XL
Lite-On DVDROM IDE
Samsung CDRW IDE
PSU is all good.
