- Sep 23, 2002
- 3,948
- 0
- 76
I was burning some files to DVD today, and I went to check if it was done, and the orange light was lit on the drive, the computer was showing a black screen, though the monitor was on.  Basically, the system was on, but was not displaying an image on my monitor.
As a result, I opened up the computer. I was able to get it to boot into WinXP, but the HDD LED light would not turn off. It kept blinking for about 5 mins. The secondary HDD showed up in device manager, but I was not able to open up MY COMPUTER to see if it was recognized there. Then, the system froze. I therefore restarted, and even before the bios screen could appear, it said DISK BOOT ERROR. Please press any key
I did that, it restarted the computer, and gave the same error.
I unplugged my primary slave HDD, and the computer seems to boot fine now. I'm thinking maybe I had a harddrive failure, since I was burning the files to DVD from the HDD that is set as slave.
The problem I have is that I was backing up that harddrive to DVD. The files are important on that HDD. Am I probably correct that it is a hard drive failure, and if it is, is there a way for me to recover my data?
Any ideas?
Any ideas?
 Facebook
Facebook Twitter
Twitter
