sze5003
Just picked up an Asus Z170 Pro Gaming Mobo, i7 6700K, and 16gb EVGA SC ddr4 3200 ram.
I have everything connected, my cpu hyper 212 installed, all power cables plugged in both the 12v and the 24 pin connectors.
I tried 1 stick of ram, tried 2, tried resetting cmos by using the jumpers. Not sure what I am missing.
Using a Corsair 750TX power supply. I connected the P+ LED and P- LED cables, power, and reset switch. What is odd is I have two power switches, not sure why but I used the power switch that is connected to the power led cables. I think the second power switch could be from my case since there is a little lever to increase and decrease fan speed.
The case is a NZXT 410.
Motherboard power light comes on Red and stays red. The mobo lights around the board slowly blink red as if it is breathing. According to Asus the red power light staying on is normal as per the manual.
I press the power button on the case, nothing. I then switch the power switch the opposite direction (writing facing bottom of the case) and I notice that once I flip the PSU switch, my case's power LED button comes on. But I don't remember this happening on the Asrock board. On my Asrock, the case's power led light would remain off until I pressed the power button.
Kind of at a loss here. I can't figure out if it is the board or what. I may try putting my old board in tomorrow and see if it turns on. I spent the whole night trying to figure out what it could be.
