Computer will not Post
GreedyBumps
When I turn the power on mobo makes no sound. Just 4 red LEDs are on. I try to boot with bare minimum CPU, 1 stick ram, 1 video, 1 HDD and still nothing. Please help.
System Specs:
DFI LANPARTY UT nF4 SLI-DR Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard - Retail
AMD Athlon 64 4000+ San Diego Integrated into Chip FSB Socket 939 Processor Model ADA4000BNBOX - Retail
eVGA 256-P2-N376-AX Geforce 6800GT 256MB GDDR3 PCI-Express x16 Video Card - Retail x 2 (but trying to boot with just 1 at a time)
Maxtor DiamondMax 10 6B250R0 250GB 7200 RPM IDE Ultra ATA133 Hard Drive - OEM
OCZ EL Platinum Revision 2 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model OCZ4001024ELDCPER2-K - Retail
ENERMAX EG565AX-VEFMA2.0-SLI ATX12V 535W Power Supply - Retail
Try reseating everything. Also try without the HD. Does the motherboard support beep-codes, or are the LED's there to indicate the error? Either way lookup the LED code/beep code in the manual. You may also try running it outside the case in order to eliminate grounding issues.
[edit] are the fans spinning? [/edit]
Fans are spinning. I have tried CMOS reset. Tried it without hard drive.
Here is a question - I am connecting 24 pin power to MOBO. There is another 4 pin plug (12v/Ground/12v/Ground) next to the 24 pin power - Do I need to power that as well?
Yes u do... Call DFI.. I had the same exact problem a week ago. It may be that your BIOS is corrupted. They may try to flash it.
I am not familiar with that MB, but my gut feels says yes. Read the manual. Your PSU is probably new enough that it has both power connectors.
