Hi everyone,
The trouble I am having is this, Started up my backup computer today and all was fine for about 2 minutes, I was able to get online with my DSL connection and search some sites. The computer then decided to restart itself. This has been problem has been going on for about a month or so.
It gave me the Amercian Megatrends Bios info, detected the HD and the CD-Rom Drive then the Bios screen went away as if it was loading windows, but I got nothing. I shut it down turnied it back on and this time it didnt even get to the bios screen. All the lights were on, the CPU fan was running but it didnt say anything on my moniter about anything booting. I tried to troubleshoot the problem, disconnecting each component that was connected to the motherboard (Basically anything with an IDE cable) and nothing really helped. Also changed the power connecters around between devices with no results.
Now the strange part about this is when I tried to reboot the machine the CD-ROM light was running, found that very strange, but after I waited about 25 minutes or so and tried turning on the computer again and it booted up just fine. I didnt use it for an extended period (just wanted to see if it would boot then I shut it down). I went into the Bios to see how hot the system was running and the temp went from about 46 Degrees C to about 50 Degrees C on the CPU in about 1 minute.
Question is what is the problem? is it a power supply on its last leg? Motherboard on its last leg?? Not enough cooling on the CPU??
The system is a
AMD Athlon XP 1800+ running windows XP (service pack 1)
K7S5A Motherboard
768 MB Memory PC-2700
40 GB Western Digital 7200 RPM HD
40 GB Seagate 7200 RPM HD
Geforce4 4200-TI 128MB Video Card
Onboard Sound Card
Any help would be greatly appreciated
The system is a
K7S5A Motherboard
Onboard Sound Card
