Dear BIOS&WinDOS-Fight-For-Power-Management Victim-
If power management is enabled in both your puter's BIOS and in WinDOS, that very well may be the cause of some beerburps...
Try disabling all power management in BIOS but leave APM enabled in WinDOS.
Or vice-versa.
Point is, completely ENABLE one of the two power management methods and completely DISABLE the other of the two.
Here's a good allegory:
Sometimes when two HeadHonchoSuits within TheCompanyBuilding each tell one ElectricMaintenanceBluecollarGuy to shut off different lights in the house at different times using two distinctly different means will sometimes makes the BluecollarGuy wanna just say *&%$it and instead go drink lotsa & lotsa beer.
Then the BlueCollarGuy does Illegal Operations & such...
hehehehe
OR...
You can completely disable all power management wherever you find it. This link describes howto:
http://members.aol.com/axcel216/newtip15.htm
And then, instead of trusting that some programmer's instructions will get along just hunkydory with your puter's BIOS programmer's instructions, ya just use yer own God-given finger to push buttons so that they're ON or OFF. Works great. And things don't become unstable. Unless, of course, ya spill the coffee on the keyboard on the finger's way to the ON/OFF button....
Kevin Kendall
"I am sending you out like sheep among wolves.
Therefore be as shrewd as snakes and as innocent as doves."
Yahshua - Matthew 10:16
