Hello, another user who's been out of the game for too long requesting some help. Thank heavens for this amazing community!
My computer's been giving me too many problems so I'm going to do a rebuild.
PC will be used for medium-high end gaming, net browsing, carelessly leaving a million things running at once. Also the occasional video/movie making, and general media usage(movies, blu-ray, tons of music).
I'm from the US.
I'm a newegg fanboy.
I'm an AMD fanboy.
I don't overclock anymore.
My budget for the parts I'd like to purchase is around $400-800.
Here's what I'm keeping:
I use dual-monitor setup, each with their own resolutions:
-Sceptre 24" widescreen, usually run 1900x1200
-Some 19" lcd, usually at 1600 x 1200
I <3 my Case.
- Antec p180(just wish it weighed a little less)
My power supply is pretty recent:
-PC Power and Cooling S75QB 750W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply compatible with core i7
-http://www.newegg.com/Product/Product.aspx?Item=N82E16817703009
Will this be sufficient?
My Video card's pretty solid:
- MSI N260GTX-T2D896 OC GeForce GTX 260 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready
-http://www.newegg.com/Product/Product.aspx?Item=N82E16814127361
I'm keeping my hard drives, 2 x SATA drives with most of my stuff.
I just spent the past week or so trying to catch up on my reading/technology, and I still feel out of the loop. I've browsed the past week or so on this forum, just looking at other people's builds and questions/suggestions.
Mainly, I guess I just need some strong suggestions for motherboard/cpu and memory. I'm also considering an SSD for OS/applications. If it can fall within my budget... Motherboard reliability is probably the most important thing to me right now, the last few builds I've used had motherboards that died and caused some headaches. Also, my timing is pretty relaxed, and if I remember right, January/February is a good time to buy, so I don't mind waiting if there's going to be a major price drop soon. Ideally I'd like to purchase within the next month.
So, in quick summary:
Budget = $400-800
Needs: Motherboard, Cpu, Memory
Possible Upgrade if within budget?: SSD
Edit: Forgot about OS! Totally out of the loop in the OS world, I've been stuck on my XP professional for like 8 years now, it's suited me fine, but I'm not opposed with giving 7 a go, which I would also need to purchase. Info/Suggestions appreciated on this topic as well.
Thanks all for your input and help!
I'm from the US.
I'm an AMD fanboy.
I <3 my Case.
Budget = $400-800
