imported_AFI
I been having a problem with the new system i built, and i cannot figure it out.
I found this website searching google, and i decided to register, and ask you guys for help.
When i goto install an operating system such as MDK Linux, or Windows XP, they just won't install. As soon as Mandrake Linux gets to the part of the install, when it makes the file systems & formats, i get an error. The error i get is "partition of hda something failed". Now when i goto install Windows XP, it be begins to copy files, then it stops and i get a blue screen error. I thought maybe my hard drive was bad, because all these system parts are brand new except the hard drive, and RAM, so i bought a new hard drive.. still the same issue. I have now 2 hard drives, one set as master, other set as slave, and both are on the same IDE cable. My bios shows the hard drives... but i cant seem to install an OS. I also tried using different IDE cables, and still same issue. Someone told me this could an issue with my ram, so i ran memtest86, and i took a picture of what it's showing.. i don't understand it. Is my ram bad? Could this be a RAM problem? I don't have anymore RAM to see if thats the case or not.
My system specs are
AMD Athlon XP 2200+
Asus A7N8X motherboard
512 MB DDR RAM (in one slot)
Seagate 40GB 7200 HD
Seagate 80GB 7200 HD
Sound Blaster Live 5.1
GeForce FX 5200
24x10x40 CD-RW
And heres the link to the picture i uploaded of what memtest86 says.
http://home.comcast.net/~kohr/pictures/memtest86.jpg
My system specs are
AMD Athlon XP 2200+
GeForce FX 5200
24x10x40 CD-RW
