Computer Problem
cusx
Hi All , i got a brand new computer with the following specs
E6750
P5K Deluxe
Corsair 2x 1GB CL4 Memory
XFX 8800GT
SilverStone Strider 560w PSU
now my problem starts with the following stories, just to let u all know how it all happen
and i'll be honest, im using pirated OS.
1) i install the OS into the computer for the very first time, WalaH, everything work fine, soon after than I installed all the drivers needed, and the WGA crack, but Microsoft instantly found out that its wasn't genuine, but i dont care bout it
2) after the next reboot, my computer hangs while its at the Windows menu, while the place where got the Task Bar and etc,
3) reboot again, it hangs again !
4) reformat again
5) all done, but it hang again after installing all drivers.
6) soon i found out that if two drivers installing at the same memory the windows would hang.
7) thus, i want to reformat my computer again, since my computer hang so easily, i cant even uninstall those drivers..
8) Major Problem Occur: My Computer Would Hang while installing the OS ! FYI, i used two different disc... and both of them would HANG , mouse couldnt move and etc..
Any Computer experts out there would mind to help me, im really Sad now, since I always reformat correctly on my old computer so while I was buying the computer, i told my mom i wanted to do it myself, but thing soon went WRONG ! :(
all of these drivers stuff I only occur it for the very first time.
Anyone Please Help me, I dont want my mom to look down upon me , Thanks All
dclive
5,626
E6750
P5K Deluxe
XFX 8800GT
4) reformat again
Buy a legal OS.
Microcenter has a basic box with Vista on it now for $199. Toss some of your hardware in there and you'd be good to go....
cusx
umm, okies, after buying original will i still HANG while installing OS ?
and original OS cost 900here which means 300USD..
cozumel
337
My first advice would be to check that the memory timings and voltage in the BIOS are as per Corsair specs.
Second, get a legal copy of Windows if the memory settings are ok then come back and ask the question again if the problem still persists with a licensed version.
cusx
Okies, got a genuine one, installed and hang on a place called Registering Componenets =X
TemjinGold
3,050
65
Your Genuine OS comes with MS tech support. Try them, they are actually quite good.
