BigFatCow
i have a MSI K7T266 Pro with an athlon XP 1800 and 256mb of ram.
i took it apart to test another system in its case and when i put it back in it didnt work so i did the normal stuff reseated everything tried the minimum stuff. and none of that worked.
what happens is when i boot it detects the CPU and the RAM and then gets stuck at wait for around 30 seconds or so and the DLED thing says red green green green which in the manual says "boot attempt - this will set low stack and boot via INT 19h" then it beeps 2 times then pause then beeps again and the DLED changes to red red green green which in the manual says "initializing hard drive controller -This will initialize IDE drive and controller" and it says on the monitor
Sec Master Drive - ATAPI Incompatible
Sec Slave Drive - ATAPI Incompatible
Press F1 to resume_
but the thing is i have no hard drives or cdroms hooked up.
and when i do hook up a HD with win2000 on it it does the same thing.
Press F1 to resume_
