Hello,
I have just built a computer which uses EPS 12V power connectors on the motherboard. I have everything hooked up right, I have checked about 10 times now and have tried disconnecting everything except the motherboard connection to the power. When I turn on the PSU, the CPU fans spin for a split second and the same goes with the PSU fan. After that, absolutely nothing happens. I have tried everything, changing the power switch to the reset button, removing everything else, but nothing is working. How do I know if it's the PSU or the motherboard or something else? I'm pretty confident it's not the switch to turn on the computer becuase I cannot imagine both the reset button and the power button not working.
The PSU is a AMS Electronics Mercury 550W and the mobo is Tyan K8S Pro.
HELP!
Thanks,
Rexxe
HELP!
Thanks,
Rexxe
