Hi there guys,
Quick diagnosis of my problem: I power on my computer, It turns on and everything is as should be when it boots up, but the problem is that the 8800 GTS Fan doesn't slow down (Which would be the typical part, since it starts powered at full speed then slows down to hit post and from there on is stress-dependent). The computer just will not post. Everything is getting adequate power. Specs:
OCZ StealthXStream 600W PUS
eVGA 8800 GTS 640MB Video Card
Asus P5N32-E PLUS 680i Chipset board.
Crucial Ballistix 2x1GB PC2-6400
1 Seagate 500 GB 7200.10 HD
1 WD 400GB 7200 RPM HD
Intel Core 2 Quad Q6600 stock cooler
4 Case Fans (Vantec branded, 3 pin, all plugged into the OPT_FAN outlets aorund the board)
Silverstone LC20M VD/IR Case
Onboard HD-Audio.
I am wondering what to do. I have independently tried to isolate everything, I've tried all slots on the PCI-E graphics cards. I've removed all HD's and tried running the computer with JUST the video card and no go. Anyone have a suggestion? I'm pretty sure it's the power supply I'm just wondering if anyone can confirm my diagnosis. The computer boots up fine won't hit post though. I've tried leaving the CMOS battery out for 15 minutes that did not help.
Has anyone had this problem?
Onboard HD-Audio.
