Computer in oil
krcat1
551
This person put the works in an aquarium full of oil
Link
Slashdot has a thread on this as well.
What do you ladies and gents think?
From what I can read, the machine was a high-ender.
Nov 11, 2004
10,855
It's possible, I believe team AMD did it with their system on display at one of those major events with coverage from Tom's Hardware.
I'm thinking about it myself, I just don't know if I can trust it not to explode on me. :p
qulAKle
233
it would be fun to get oil to the boiling boint with 2x2 preshots and then throw in some fries into the case and fry them lmao.
NokiaDude
3,966
meh, someone did that with another liquid. Vegetable oil will leave everything slimy when they take it out.
ty1er
807
i would think that once the oil started to warm up it might act like a insulator, keeping the system warm.... (this is not based on any technical info, just a hunch.)
Deep Fried Motherboards!
alexXx
502
they use mineral oil. I odnt know what mineral oil it, but it is obviously non-conductive. Heat wise i think it is a great idea. All liquids will have a large heat capacity,(far higher than air) so everything in the system will be the exact same temp(the cpu may be 2C higher or something.. Then all you would need is a radiator of some sort and some fans the mix the liquid around and you should be golden. I predict in the future, this will be very common for computer.
edit, yes it is electrically non-conductive. http://www.shell-lubricants.com/Electrical/diala_hfx.html
Thezeroone
48
I've heard of something like this, but I was told refrigeration piping was run through the oil to keep it cool.
S Random
236
It wont be common because of weight issues, if there was a way to have it done with water... it would be more popular (with a protective bag around mobo)
BillyBobJoel71
2,610
still water cooling is the most they will get to that will be practical. i would think they have to pump it so it doesn't develpor bacteria and odor.
akugami
6,210
2,552
Vegetable oil leaves a really sticky residue. Granted all oil will leave a residue but veggie oil has lots of impurities compared to something like mineral oil...very hard to clean up. Not to mention the fact that veggie oil smells. Interesting to do but I wouldn't subject any hardware I planned to keep long term to that type of ordeal.
alexXx
502
Mineral oil is less dense than water and therefor lighter, so i assume that you didnt mean water was a good idea because of weight...
logic0010
1,099
ok im bored and i have a p2 that ill test it with i have a shell dealer 7 miles from me if the oil is cheap im gonna do it if it dosent fry my p2 i have a tbird 1.2 that ill try oc in it
i hate my epox ep-8rda anyways iv been looking for something to do iv already made a lotof window modded harddrives iv run out of mod ideas so this will be fun ill keep you all posted
Granorense
699
Great, good luck!
w00t
5,545
Link
it isnt hi-end.
intel celeron 550MHz
192 MB Ram
30GB Festplatte
GeForce FX 5200 (habe ich aufgerüstet damit ich einen DVI anschluss habe)
