Computer help!
RSanders
293
My computer has been acting up as of late. The computer will just shut off completely at random. No logging off.. just shut down.
Now there is a red light shining inside the case afterwards.. and I have to turn the power switch on the back of the case off, then back on before it will boot up again.
I think it is either Overheating or a RAM issue.. but not certain.
This is an
AMD Athlon 2500+
512MB of ram (1 stick)
80gb hd
ati radoen 9800 pro
guess thats all the stuff..
Thanks,
- Ryan
Boonesmi
14,448
sounds like faulty memory or powersupply. or possibly a mobo going bad
i would check the motherboard for any bulging or leaking capasitors.
also download memtest and check for faulty memory. ( memtest.org )
Machine350
537
This may sound silly, but check to make sure all your fans are running. Something could be overheating.
