Computer hardware problem. Sometimes no post/bluescreen
tjcason
11
So I have an intermittent computer problem which is hard to repeat, so I was hoping that I'd explain what my computer is doing and hopefully it'll raise some red flags about what particular piece of hardware is having issues here.
I brought my computer to my parents house for Christmas break and as soon as I got home, the problem started. I plugged everything in, and the computer wouldn't post. I pressed the power button on the case, the fans spun up, but no display. I hard stopped it and tried again. Same story.
This happened a few times and I opened my case and moved my graphics card to a different slot to see if possibly the slot on my motherboard had gone bad and I just wasn't getting display from that. It booted this time. Curious, I moved it back to its old spot, it booted again. Thinking it had rattled out of place somehow on the way, I thought my problems were over. I put everything back together and booted into windows, no problem, even played a few games. I ran chkdsk and it found no bad sectors and no corrupt data.
Two days passed and the computer still worked fine, then I woke up on Monday and started it and it wouldn't post again. Again I hard stopped it and pressed the button again, and it booted this time, no moving of graphics card required. It was a bit sluggish to boot but it did and I logged in, and about 5 minutes into loading on my desktop, I got a bluescreen: Code "PAGE_FAULT_IN_NONPAGED_AREA ***STOP: 0x0000050 (0xFFFFF8A235BC8EF8, 0x000000000000000001, 0xFFFFF80003E0E627, 0x000000000000000005)"
This told me if it was the first time I'd seen it to just restart my computer and see if I got it again, so I tried again.
This time it booted normally, quickly too. Getting suspicious I began looking on the internet for what the code meant and after about an hour of searching, I decided to run Furmark to see if it was a power problem, the r9 280X by sapphire is a very power thirsty card after all. I ran the Furmark for about 10 minutes and decided to add a new level to it and opened up Prime95's blend test and immediately I got a different bluescreen : Code "MEMORY_MANAGEMENT *** STOP: 0x0000001A *0x000000000050003,0xFFFFF70001080000, 0x000000000000B45B, 0x00000000215BE049) "
I rebooted and ran Prime95's blend test and though my computer didn't bluescreen, the test immediately failed, suggesting there was a hardware problem. I thought this was a clear indication that my memory had started to fail so I got a copy of memtest86 and ran it for 36 hours, which was about 6 passes and got 0 errors. After this amount of time I began to think that it may just be a loose connection so I stopped the test, shut down, unplugged the machine, and unplugged and replugged every connection into and out of the motherboard.
That was last night. This morning I booted my computer and decided to do a timelapse video of a few hundred RAW files I took the other day, I opened up photoshop (Which has execution files on a different harddrive than the boot drive, a PNY 128 GB SSD) and started to load each of the 230 photos as layers with bridge, in the task manager I watched the memory usage rise to 70% when I suddenly got a third bluescreen: Code "PAGE_FAULT_IN_NONPAGED_AREA *** STOP: 0x00000050 (0xFFFF9600006E174, 0x00000000000000008, 0xFFFFF9600006E174,0x00000000000000000)"
So here I am today, confused as heck, just trying to figure out where to start to try to troubleshoot this issue. Could anyone lend some advice? My specs are below if they help. Thank you so much for your time in advance.
Specs:
Windows 7 Ultimate Edition
Corsair TX 750 - PSU
Sapphire r9 280X - GPU
AMD FX 6100 - CPU
16GB (4x4GB) Corsair Vengeance - RAM
ASUS M5A97 - Motherboard
WD Black 1TB - Boot Drive
Corsair Carbide 200r - Case
VirtualLarry
56,587
10,227
Hmm, sounds like you are having a rough time. But failing Prime95 right off isn't a good sign.
How old is your PSU? Are you overclocked at all? If you are, reset the BIOS to defaults, so we can get a good baseline for testing. (Don't forget to re-set the boot drive, and SATA mode (AHCI / IDE / RAID) if your reset the BIOS.)
Have you re-seated your RAM already yet? That's what I would try next. Then try Prime95 Blend again. And keep an eye on your temps. How dusty is your CPU heatsink, and is the fan spinning?
John Connor
22,757
619
121
Have you installed a program recently or made any changes recently? I'm wondering if it's your hard drive. You said you ran the test. What does smart data say for the hard drive? This is definitely a stumper.
MongGrel
38,466
3,067
121
Sounds like your WD Black might be failing to me.
I usually put those in all my PC's for storage even if they have a couple of SSD for OS.
Nothing is bullet proof, I think one of my old WD RE3's in my Areca Hardware RAID 10 is maybe failing these days out of the 4 of them.
For a first post, I seems you know a lot to begin with.
tjcason
11
It is a little rough but I'm glad you all are here to help.
My PSU is only about a year and a half old. I did reset my BIOS to defaults to see if it was just the overclock. It was 1866 RAM that was running at 1600 and a 3100Mhz CPU running at 3900, so it wasn't super aggressive, but it failed again, so I just put it back at speed while I was doing memtest so it would A: Run faster and B: catch a possible problem at the speed I was running them.
When I was testing the RAM I did remove each stick and put them in again, so they are all reseated. My temps are good, CPU at idle is 14C, and under heavy load it's about 40C (I've got a really beefy CPU cooler that I just sucked all the dust off of before I came home). Hard drives are sitting around 30C. HD0: 32C, HD1: 30C, HD2: 26C, GPU idle: 36C. CPU load: 35C. (Also I should note that I ran Prime95 to get these numbers and it didn't fail immediately.)
The fans are all spinning, and they're as free from dust as I can get them.
tjcason
11
So the only thing that I've really installed recently is the AMD Catalyst Crimson upgrade, but I did that back at home and had it installed for a few days before coming home and had no problems.
I ran chkdsk and I'll give the data from eventviewer here:
Chkdsk was executed in read-only mode on a volume snapshot.
Checking file system on C:
The type of the file system is NTFS.
Volume label is 1TB.
WARNING! F parameter not specified.
Running CHKDSK in read-only mode.
CHKDSK is verifying files (stage 1 of 3)...
657408 file records processed.
File verification completed.
4098 large file records processed.
0 bad file records processed.
2 EA records processed.
47 reparse records processed.
CHKDSK is verifying indexes (stage 2 of 3)...
842498 index entries processed.
Index verification completed.
0 unindexed files scanned.
0 unindexed files recovered.
CHKDSK is verifying security descriptors (stage 3 of 3)...
657408 file SDs/SIDs processed.
Cleaning up 11 unused index entries from index $SII of file 0x9.
Cleaning up 11 unused index entries from index $SDH of file 0x9.
Cleaning up 11 unused security descriptors.
Security descriptor verification completed.
92546 data files processed.
CHKDSK is verifying Usn Journal...
35310744 USN bytes processed.
Usn Journal verification completed.
Windows has checked the file system and found no problems.
976758783 KB total disk space.
761201812 KB in 537255 files.
276032 KB in 92547 indexes.
0 KB in bad sectors.
790495 KB in use by the system.
65536 KB occupied by the log file.
214490444 KB available on disk.
4096 bytes in each allocation unit.
244189695 total allocation units on disk.
53622611 allocation units available on disk.
I felt that since there were no bad sectors, there was no need to pursue this any further, however I got your S.M.A.R.T. data in case it was useful and the data is here from CrystalDiskInfo 6.6.1:
CrystalDiskInfo 6.6.1 (C) 2008-2015 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 7 Ultimate SP1 [6.1 Build 7601] (x64)
Date : 2015/12/26 1:52:34
-- Controller Map ----------------------------------------------------------
+ AMD SATA Controller [ATA]
- TOSHIBA DT01ACA300 SATA Disk Device
- SanDisk Ultra II 480GB SATA Disk Device
- WDC WD10 02FAEX-00Z3A0 SATA Disk Device
- SSD2SC12 0G3LA726B087-370 SATA Disk Device
- ASUS DRW-24B1ST a SATA CdRom Device
+ Virtual CloneDrive [SCSI]
- ELBY CLONEDRIVE SCSI CdRom Device
-- Disk List ---------------------------------------------------------------
(1) TOSHIBA DT01ACA300 : 3000.5 GB [0/0/0, pd1]
(2) SanDisk Ultra II 480GB : 480.1 GB [1/0/0, pd1] - sd
(3) WDC WD1002FAEX-00Z3A0 : 1000.2 GB [2/0/0, pd1] - wd
(4) SSD2SC120G3LA726B087-370P : 120.0 GB [3/0/0, pd1] - sf
Model : TOSHIBA DT01ACA300
Firmware : MX6OABB0
Serial Number : 44MY53GGS
Disk Size : 3000.5 GB (8.4/137.4/3000.5/3000.5)
Buffer Size : Unknown
Queue Depth : 32
# of Sectors : 5860533168
Rotation Rate : 7200 RPM
Interface : Serial ATA
Major Version : ATA8-ACS
Minor Version : ATA8-ACS version 4
Transfer Mode : SATA/600 | SATA/600
Power On Hours : 4117 hours
Power On Count : 545 count
Temperature : 35 C (95 F)
Health Status : Good
Features : S.M.A.R.T., APM, 48bit LBA, NCQ
APM Level : 0000h [OFF]
AAM Level : ----
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 100 100 _16 000000000000 Read Error Rate
02 141 141 _54 000000000042 Throughput Performance
03 148 148 _24 0008015F01AA Spin-Up Time
04 100 100 __0 000000000637 Start/Stop Count
05 100 100 __5 000000000000 Reallocated Sectors Count
07 100 100 _67 000000000000 Seek Error Rate
08 119 119 _20 000000000023 Seek Time Performance
09 100 100 __0 000000001015 Power-On Hours
0A 100 100 _60 000000000000 Spin Retry Count
0C 100 100 __0 000000000221 Power Cycle Count
C0 _99 _99 __0 000000000638 Power-off Retract Count
C1 _99 _99 __0 000000000638 Load/Unload Cycle Count
C2 171 171 __0 003A000B0023 Temperature
C4 100 100 __0 000000000000 Reallocation Event Count
C5 100 100 __0 000000000000 Current Pending Sector Count
C6 100 100 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
-- IDENTIFY_DEVICE ---------------------------------------------------------
0 1 2 3 4 5 6 7 8 9
000: 045A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2020 2020 2020 2034 344D 5935 3347 4753
020: 0003 0000 0038 4D58 364F 4142 4230 544F 5348 4942
030: 4120 4454 3031 4143 4133 3030 2020 2020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 4000 2F00
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0110
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000
070: 0000 0000 0000 0000 0000 001F 170E 0006 005E 0044
080: 01FC 0029 746B 7D69 4773 7469 BC41 4763 407F 00F0
090: 0000 0000 FFFE 0000 0000 0008 00CA 00F9 2710 0000
100: A3B0 5D50 0001 0000 00CA 0000 6003 5A87 5000 039F
110: F4DB 5974 0000 0000 0000 0000 0000 0000 0000 409C
120: 409C 0000 0000 0000 0000 0000 0000 0000 0009 000B
130: 0000 0000 2180 0DF1 FA20 0001 4000 2004 0011 0000
140: 0000 0806 0707 0511 0608 0607 0707 0000 0000 0000
150: 0000 0006 364E 4242 0000 0806 0000 5DBD FFFF 8000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0002 0000
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 003D 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 1C20 0000 0000
220: 0000 0000 103F 0021 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 03E0 0000 0000 0000 0000
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 C7A5
-- SMART_READ_DATA ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 10 00 01 0B 00 64 64 00 00 00 00 00 00 00 02 05
010: 00 8D 8D 42 00 00 00 00 00 00 03 07 00 94 94 AA
020: 01 5F 01 08 00 00 04 12 00 64 64 37 06 00 00 00
030: 00 00 05 33 00 64 64 00 00 00 00 00 00 00 07 0B
040: 00 64 64 00 00 00 00 00 00 00 08 05 00 77 77 23
050: 00 00 00 00 00 00 09 12 00 64 64 15 10 00 00 00
060: 00 00 0A 13 00 64 64 00 00 00 00 00 00 00 0C 32
070: 00 64 64 21 02 00 00 00 00 00 C0 32 00 63 63 38
080: 06 00 00 00 00 00 C1 12 00 63 63 38 06 00 00 00
090: 00 00 C2 02 00 AB AB 23 00 0B 00 3A 00 00 C4 32
0A0: 00 64 64 00 00 00 00 00 00 00 C5 22 00 64 64 00
0B0: 00 00 00 00 00 00 C6 08 00 64 64 00 00 00 00 00
0C0: 00 00 C7 0A 00 C8 C8 00 00 00 00 00 00 00 00 00
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 84 00 3E 56 01 5B
170: 03 00 01 00 01 FF 00 70 01 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 AF
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 10 00 01 10 00 00 00 00 00 00 00 00 00 00 02 36
010: 00 00 00 00 00 00 00 00 00 00 03 18 00 00 00 00
020: 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00
030: 00 00 05 05 00 00 00 00 00 00 00 00 00 00 07 43
040: 00 00 00 00 00 00 00 00 00 00 08 14 00 00 00 00
050: 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00
060: 00 00 0A 3C 00 00 00 00 00 00 00 00 00 00 0C 00
070: 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00
080: 00 00 00 00 00 00 C1 00 00 00 00 00 00 00 00 00
090: 00 00 C2 00 00 00 00 00 00 00 00 00 00 00 C4 00
0A0: 00 00 00 00 00 00 00 00 00 00 C5 00 00 00 00 00
0B0: 00 00 00 00 00 00 C6 00 00 00 00 00 00 00 00 00
0C0: 00 00 C7 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64
Model : SanDisk Ultra II 480GB
Firmware : X41100RL
Serial Number : 154487415605
Disk Size : 480.1 GB (8.4/137.4/480.1/480.1)
Queue Depth : 32
# of Sectors : 937703088
Rotation Rate : ---- (SSD)
Major Version : ACS-2
Minor Version : ACS-2 Revision 3
Power On Hours : 24 hours
Power On Count : 29 count
Host Reads : 5 GB
Host Writes : 5 GB
NAND Writes : 0 GB
Temperature : 31 C (87 F)
Health Status : Good (100 %)
Features : S.M.A.R.T., APM, 48bit LBA, NCQ, TRIM
APM Level : 0080h [ON]
AAM Level : ----
05 100 100 __4 000000000000 Reallocated Block Count
09 100 100 __0 000000000018 Power On Hours
0C 100 100 __0 00000000001D Power Cycle Count
A5 100 100 __0 000000010000
A6 100 100 __0 000000000000 Min W/E Cycle
A7 100 100 __0 000000000042 Max Bad Block/Die
A8 100 100 __0 000000000000 Maximum Erase Cycle
A9 100 100 __0 000000000279 Total Bad Block
AA 100 100 __0 000000000000
AB 100 100 __0 000000000000 Program Fail Count
AC 100 100 __0 000000000000 Erase Fail Count
AD 100 100 __0 000000000000 Average Erase Cycle
AE 100 100 __0 00000000000D Unexpected Power Loss Count
B8 100 100 __0 000000000000
BB 100 100 __0 000000000000 Reported Uncorrectable Errors
BC 100 100 __0 000000000000
C2 _69 _64 __0 00400015001F Temperature
C7 100 100 __0 000000000000
E6 100 100 __0 000000000000 Percentage Total P/E Count
E8 100 100 __0 000000000064 Spare Block Remaining
E9 100 100 __0 000000000000 Total GB Written To NAND
EA 100 100 __0 000000000005
F1 253 253 __0 000000000005 Total GB Written
F2 253 253 __0 000000000005 Total GB Read
F4 __0 100 __0 000000000000
0 1 2 3 4 5 6 7 8 9
000: 0000 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 3135 3434 3837 3431 3536 3035 2020 2020 2020 2020
020: 0000 0000 0000 5834 3131 3030 524C 5361 6E44 6973
030: 6B20 556C 7472 6120 4949 2034 3830 4742 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8001 4000 2F00
050: 4000 0200 0000 0006 3FFF 0010 003F FC10 00FB D101
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 4D20
070: 0000 0000 0000 0000 0000 001F 870E 0006 004C 0044
080: 03F0 0110 346B 7D09 4123 3469 BC09 4123 407F 0001
090: 0012 0080 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 36B0 37E4 0000 0000 0000 0010 4000 0000 5001 B44F
110: 03BF DF35 0000 0000 0000 0000 0000 0000 0000 401C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 0000
130: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0003 0001
170: 0000 0000 0000 0000 0000 0000 2020 2020 2020 2020
180: 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020
190: 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020
200: 2020 2020 2020 2020 2020 2020 0000 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 0001 0000 0000
220: 0000 0000 10FF 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 0080 0000 0000 0000 0000
000: 04 00 05 32 00 64 64 00 00 00 00 00 00 00 09 32
010: 00 64 64 18 00 00 00 00 00 00 0C 32 00 64 64 1D
020: 00 00 00 00 00 00 A5 32 00 64 64 00 00 01 00 00
030: 00 00 A6 32 00 64 64 00 00 00 00 00 00 00 A7 32
040: 00 64 64 42 00 00 00 00 00 00 A8 32 00 64 64 00
050: 00 00 00 00 00 00 A9 32 00 64 64 79 02 00 00 00
060: 00 00 AA 32 00 64 64 00 00 00 00 00 00 00 AB 32
070: 00 64 64 00 00 00 00 00 00 00 AC 32 00 64 64 00
080: 00 00 00 00 00 00 AD 32 00 64 64 00 00 00 00 00
090: 00 00 AE 32 00 64 64 0D 00 00 00 00 00 00 B8 32
0A0: 00 64 64 00 00 00 00 00 00 00 BB 32 00 64 64 00
0B0: 00 00 00 00 00 00 BC 32 00 64 64 00 00 00 00 00
0C0: 00 00 C2 22 00 45 40 1F 00 15 00 40 00 00 C7 32
0D0: 00 64 64 00 00 00 00 00 00 00 E6 32 00 64 64 00
0E0: 00 00 00 00 00 00 E8 33 00 64 64 64 00 00 00 00
0F0: 00 00 E9 32 00 64 64 00 00 00 00 00 00 00 EA 32
100: 00 64 64 05 00 00 00 00 00 00 F1 30 00 FD FD 05
110: 00 00 00 00 00 00 F2 30 00 FD FD 05 00 00 00 00
120: 00 00 F4 32 00 00 64 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 11
170: 03 00 01 00 02 0A 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7
000: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0E0: 00 00 00 00 00 00 E8 04 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10
Model : WDC WD1002FAEX-00Z3A0
Firmware : 05.01D05
Serial Number : WD-WCATRA784983
Disk Size : 1000.2 GB (8.4/137.4/1000.2/1000.2)
Queue Depth : 32
# of Sectors : 1953525168
Rotation Rate : Unknown
Minor Version : ----
Power On Hours : 8167 hours
Power On Count : 1563 count
Temperature : 37 C (98 F)
Features : S.M.A.R.T., 48bit LBA, NCQ
APM Level : ----
AAM Level : ----
01 200 189 _51 0000000000CF Read Error Rate
03 182 176 _21 000000000F1A Spin-Up Time
04 _99 _99 __0 000000000691 Start/Stop Count
05 200 200 140 000000000000 Reallocated Sectors Count
07 100 253 __0 000000000000 Seek Error Rate
09 _89 _89 __0 000000001FE7 Power-On Hours
0A 100 100 __0 000000000000 Spin Retry Count
0B 100 100 __0 000000000000 Recalibration Retries
0C _99 _99 __0 00000000061B Power Cycle Count
C0 200 200 __0 000000000135 Power-off Retract Count
C1 200 200 __0 00000000055B Load/Unload Cycle Count
C2 110 _85 __0 000000000025 Temperature
C4 200 200 __0 000000000000 Reallocation Event Count
C5 200 200 __0 000000000000 Current Pending Sector Count
C6 200 200 __0 000000000000 Uncorrectable Sector Count
C8 200 200 __0 000000000000 Write Error Rate
0 1 2 3 4 5 6 7 8 9
000: 427A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2057 442D 5743 4154 5241 3738 3439 3833
020: 0000 0000 0032 3035 2E30 3144 3035 5744 4320 5744
030: 3130 3032 4641 4558 2D30 305A 3341 3020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00
050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB 0110
070: 0000 0000 0000 0000 0000 001F 170E 0006 0044 0044
080: 01FE 0000 746B 7D61 4123 7469 BC41 4123 407F 0053
090: 0053 0000 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 6DB0 7470 0000 0000 0000 0000 0000 0000 5001 4EE2
110: 07D3 A722 0000 0000 0000 0000 0000 0000 0000 4018
120: 4018 0000 0000 0000 0000 0000 0000 0000 0029 0000
130: 0000 0000 0000 16E2 0000 0000 0000 0000 0000 0000
140: 0000 0000 0004 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 3037 0000 0000 0000
210: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
220: 0000 0000 103E 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 1000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 74A5
000: 10 00 01 2F 00 C8 BD CF 00 00 00 00 00 00 03 27
010: 00 B6 B0 1A 0F 00 00 00 00 00 04 32 00 63 63 91
020: 06 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00
030: 00 00 07 2E 00 64 FD 00 00 00 00 00 00 00 09 32
040: 00 59 59 E7 1F 00 00 00 00 00 0A 32 00 64 64 00
050: 00 00 00 00 00 00 0B 32 00 64 64 00 00 00 00 00
060: 00 00 0C 32 00 63 63 1B 06 00 00 00 00 00 C0 32
070: 00 C8 C8 35 01 00 00 00 00 00 C1 32 00 C8 C8 5B
080: 05 00 00 00 00 00 C2 22 00 6E 55 25 00 00 00 00
090: 00 00 C4 32 00 C8 C8 00 00 00 00 00 00 00 C5 32
0A0: 00 C8 C8 00 00 00 00 00 00 00 C6 30 00 C8 C8 00
0B0: 00 00 00 00 00 00 C7 32 00 C8 C8 00 00 00 00 00
0C0: 00 00 C8 08 00 C8 C8 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 82 00 84 3F 01 7B
170: 03 00 01 00 02 BD 05 00 00 00 00 00 00 00 00 00
180: 00 00 01 04 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30
000: 10 00 01 33 C8 C8 C8 C8 00 00 00 00 00 00 03 15
010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00
030: 00 00 07 00 64 64 64 64 00 00 00 00 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00
050: 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00 00
060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 C0 00
070: 00 00 00 00 00 00 00 00 00 00 C1 00 00 00 00 00
080: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00
090: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C5 00
0A0: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00
0B0: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
0C0: 00 00 C8 00 C8 C8 C8 C8 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ED
Model : SSD2SC120G3LA726B087-370P
Firmware : 524ABBF0
Serial Number : PNY14110000456100181
Disk Size : 120.0 GB (8.4/120.0/120.0/120.0)
Queue Depth : 32
# of Sectors : 234441648
Power On Hours : 151 hours
Power On Count : 900 count
Host Reads : 1477 GB
Host Writes : 3846 GB
Temperature : 30 C (86 F)
APM Level : 00FEh [ON]
AAM Level : ----
ID Cur Wor Thr Raw Values (7) Attribute Name
01 120 120 _50 00000000000000 Raw Read Error Rate
05 100 100 __3 00000000000000 Retired Block Count
09 100 100 __0 14D0B600000097 Power-on Hours
0C 100 100 __0 00000000000384 Power Cycle Count
AB __0 __0 __0 00000000000000 Program Fail Count
AC __0 __0 __0 00000000000000 Erase Fail Count
AE __0 __0 __0 00000000000001 Unexpected Power Loss Count
B1 __0 __0 __0 00000000000007 Wear Range Delta
B5 __0 __0 __0 00000000000000 Program Fail Count
B6 __0 __0 __0 00000000000000 Erase Fail Count
BB 100 100 __0 00000000000000 Reported Uncorrectable Errors
C2 _30 _58 __0 00000B003A001E Temperature
C3 120 120 __0 00000000000000 On-the-Fly ECC Uncorrectable Error Count
C4 100 100 __3 00000000000000 Reallocation Event Count
C9 120 120 __0 00000000000000 Uncorrectable Soft Read Error Rate
CC 120 120 __0 00000000000000 Soft ECC Correction Rate
E6 100 100 __0 00000000000064 Life Curve Status
E7 100 100 _10 00000000000000 SSD Life Left
E9 __0 __0 __0 00000000001291
EA __0 __0 __0 00000000000F06
F1 __0 __0 __0 00000000000F06 Lifetime Writes from Host
F2 __0 __0 __0 000000000005C5 Lifetime Reads from Host
0 1 2 3 4 5 6 7 8 9
000: 0C5A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 504E 5931 3431 3130 3030 3034 3536 3130 3031 3831
020: 0000 0000 0004 3532 3441 4242 4630 5353 4432 5343
030: 3132 3047 334C 4137 3236 4230 3837 2D33 3730 5020
050: 4001 0200 0200 0007 3FFF 0010 003F FC10 00FB 0110
060: 4BB0 0DF9 0000 0007 0003 0078 0078 0078 0078 0F08
070: 0000 0000 0000 0000 0000 001F F70E 0006 004C 0044
080: 01FC 0110 746B 7569 6163 7429 B449 6163 407F 0001
090: 0001 00FE FFFE 0000 0000 0000 0000 0000 0000 0000
100: 4BB0 0DF9 0000 0000 0000 0001 4000 0000 5F8D B4C1
110: 4110 0181 0000 0000 0000 0000 0000 0000 0000 405A
200: 0000 0000 0000 0000 0000 0000 0025 0000 0000 4000
210: 0000 0000 0100 0000 0000 0000 0000 0001 0000 0000
220: 0000 0000 103F 0000 0000 0000 0000 0000 0000 0000
230: 4BB0 0DF9 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 E3A5
000: 0A 00 01 33 00 78 78 00 00 00 00 00 00 00 05 33
010: 00 64 64 00 00 00 00 00 00 00 09 32 00 64 64 97
020: 00 00 00 B6 D0 14 0C 32 00 64 64 84 03 00 00 00
030: 00 00 AB 0A 00 00 00 00 00 00 00 00 00 00 AC 32
040: 00 00 00 00 00 00 00 00 00 00 AE 30 00 00 00 01
050: 00 00 00 00 00 00 B1 00 00 00 00 07 00 00 00 00
060: 00 00 B5 0A 00 00 00 00 00 00 00 00 00 00 B6 32
070: 00 00 00 00 00 00 00 00 00 00 BB 12 00 64 64 00
080: 00 00 00 00 00 00 C2 22 00 1E 3A 1E 00 3A 00 0B
090: 00 00 C3 1C 00 78 78 00 00 00 00 00 00 00 C4 33
0A0: 00 64 64 00 00 00 00 00 00 00 C9 1C 00 78 78 00
0B0: 00 00 00 00 00 00 CC 1C 00 78 78 00 00 00 00 00
0C0: 00 00 E6 13 00 64 64 64 00 00 00 00 00 00 E7 13
0D0: 00 64 64 00 00 00 00 00 00 00 E9 32 00 00 00 91
0E0: 12 00 00 00 00 00 EA 32 00 00 00 06 0F 00 00 00
0F0: 00 00 F1 32 00 00 00 06 0F 00 00 00 00 00 F2 32
100: 00 00 00 C5 05 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 79
170: 03 00 01 00 01 24 02 00 00 00 00 00 00 00 00 00
000: 0A 00 01 32 00 00 00 00 00 00 00 00 00 00 05 03
010: 00 00 00 00 00 00 00 00 00 00 09 00 00 00 00 00
020: 00 00 00 00 00 00 0C 00 00 00 00 00 00 00 00 00
030: 00 00 AB 00 00 00 00 00 00 00 00 00 00 00 AC 00
040: 00 00 00 00 00 00 00 00 00 00 AE 00 00 00 00 00
050: 00 00 00 00 00 00 B1 00 00 00 00 00 00 00 00 00
060: 00 00 B5 00 00 00 00 00 00 00 00 00 00 00 B6 00
070: 00 00 00 00 00 00 00 00 00 00 BB 00 00 00 00 00
090: 00 00 C3 00 00 00 00 00 00 00 00 00 00 00 C4 03
0A0: 00 00 00 00 00 00 00 00 00 00 C9 00 00 00 00 00
0B0: 00 00 00 00 00 00 CC 00 00 00 00 00 00 00 00 00
0C0: 00 00 E6 00 00 00 00 00 00 00 00 00 00 00 E7 0A
0D0: 00 00 00 00 00 00 00 00 00 00 E9 00 00 00 00 00
0E0: 00 00 00 00 00 00 EA 00 00 00 00 00 00 00 00 00
0F0: 00 00 F1 00 00 00 00 00 00 00 00 00 00 00 F2 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5C
It's kind of a mess to read, but hopefully you find it useful.
Each of the drives says that the health of the drive is good.
tjcason
11
If it's failing it's doing a really great job of hiding it. :p
tjcason
11
It's possible, but I guess I feel like it's unlikely because it fails to post on occasion. It's apparently the newest driver there is so far, so I'm unsure if that's what could cause it, ya know?
Steltek
3,487
1,244
Were it my system, I'd swap the power supply given the tendency to fail to boot.
tjcason
11
Well on a friend's advice, I refreshed the paging file and so far (It's intermittent so this means basically nothing) I haven't had a problem yet.
The PSU is relatively new, (about a year old) and it's Corsair. The only other PSU I have has suspect quality and probably wouldn't be a good one to test on. If I have additional problems I will try it anyway. What makes you think it's the PSU and not say, the memory?
Steltek
3,487
1,244
Just because the power supply is relatively new doesn't mean it can't be in the process of developing a fault. Corsair power supplies (excepting their cheap entry level units) are generally above average in quality, but they can produce bad units just like everybody else.
A flaky power supply can cause of random and intermittent issues that mimic memory and even CPU errors due to voltage fluctuations.
If the problem recurs, I'd start by swapping the power supply simply because I need to know without a doubt that is functioning properly. It is, after all, the cornerstone of your system -- everything else you add to that system absolutely depends on it to be working properly.
tjcason
11
I have a meter, is there any way I can test it to make sure?
John Connor
22,757
619
121
You could really only measure voltage. If you have a standard molex connector, flip the meter to DC volts and connect the black prob to the black wire and the red prob to the yellow wire. You should read 12 volts. Of course the Comp needs to be on, otherwise you can take the MOBO connector and short the black and green wire to start the PSU.
nfriedly
33
nfriedly.com
You don't happen to have any local friends with PCs, do you? If so, you could try swapping parts one at a time - when they stert getting errors instead of you, you'll know you found the culprit. (They'd have to be a pretty good friend though!)
tjcason
11
Those are things I should also be able to read in the BIOS though, right?
tjcason
11
Unfortunately the one friend I had that I thought would do that with me flaked, so... with you all's help, we're gonna get it done.
John Connor
22,757
619
121
You could, but I would rather use a meter just in case BIOS reports the wrong voltages. I mean would you trust a droid's voltage read out if it meant that 5 extra volts meant he became self-aware or not? :D
tjcason
11
I mean, if it were analog, yeah. :p
